should I replace the coolant, clutch, and brake hoses along with the fuel lines if the bike is 20 years old and was sitting for 3 years?
im adding this into the post, I have a suzuki intruder 750. I dont have a harley yet, thought u guys could still help thou.
On a more serious note, if thats possible, the bike may not be equiped with a radiator, coolant, or coolant hoses, ESPECIALLY if its an hd. But it may have if its an import.
But i would say all thoses things would be worth changing as they would make the bike a lot safer to ride.
You can't use the orange stuff, It is specifically written in your owners manual that you must use harley coolant. It has a special ethylene glycol which was engineered by HD to work in the open air environment without leaking on to the ground.
OK LMAO so I had to look at Road kills other posts. I didn't spend much time looking but saw enough to get the impression he is a nube wanna-be who not only does not own a Harley but has no bike at all. Based on this post and some of the others I read his user name is quite appropriate.
Make sure to change the blinker fluid and the muffler belt as those are assuredly shot as well.
Reason: because
