Anyone had their windshield cut down?
Old Sep 17, 2008 | 11:45 PM
Roadjunkie1's Avatar
Roadjunkie1
Tape it
Mark it
Cut it with a GOOD jig saw. (If you're lucky enough to have a band saw even better.)
Finish with a belt sander (fine grit)
Take your time, will look great.
DO NOT use a roto zip or dremel tool. Both will float and screw things up regardless of what the wannabe experts might try to tell you.
Have done it a dozen times or so.
Will look great!
Old Sep 18, 2008 | 02:57 AM
TheBagger's Avatar
TheBagger
A couple of things.. use a fine metal cutting blade on the jigsaw will leave you with less sanding. Trace the edge on some stiff paper, move it down, mark it, tape it up good to prevent scratches from the jigsaw. I used a orbital sander and then went over it by hand and rounded the edge to match the factory. Wipe the edge with a little lacquer thinner and you won't be able to tell it from the factory edge.
Old Sep 18, 2008 | 03:52 AM
dugan's Avatar
dugan
good tips on how to do it but I'm not going there. One, I don't own any type of tool to cut it and two, I will leave it to the professionals. Now I need to decide how much to have them cut down.
Old Sep 18, 2008 | 05:48 AM
stafford's Avatar
stafford
Level from the tip of your nose
Old Sep 18, 2008 | 06:10 AM
Fogoms's Avatar
Fogoms
Get some thin tape and mark across the windshield where you think it should be cut (you should be looking just over the windshield while sitting comfortably in your normal riding position). Go for a ride. Repeat as necessary until you've got it right. Then bring it to a good glass shop. Cost me 20 bux, worth every penny. Can't tell it's been cut.
Old Sep 18, 2008 | 06:18 AM
Eddielx's Avatar
Eddielx
I cut mine with a jig saw.then i used a file to round the edge then I finished it with a power sander.I did it with the windshield on the bike.
Old Sep 18, 2008 | 08:49 AM
SciFiGuy's Avatar
SciFiGuy
Originally Posted by aviator
I took the easy way out. I had a glass company do it for $20.00 I marked it, they cut and polished the edges.
aviator,
Do you mind if I ask which glass company here in S.A. you used?
Need to get mine cut down a little bit also.
Thanks.
Old Sep 18, 2008 | 09:05 AM
barjbar's Avatar
barjbar
I paid a plastics firm $25. Marked the height and they cut it and polished it. Looks stock. If you're in Oakland county in Michigan, I can tell you where they're located. I don't have the tools nor the experience, I'd rather pay someone. I went to a glass store, Henderson glass, and asked them if they can cut it. They referred me to the other company.
Old Sep 18, 2008 | 09:19 AM
honestbob's Avatar
honestbob
I did just like that, only the plate on the jig saw went thru the tape and sctatched the plastic. I'd suggest putting a double layer of tape on.
Old Sep 18, 2008 | 09:43 AM
golfblues's Avatar
golfblues
I did mine & you can't tell the difference from a factory job. I followed this video & it worked like a charm. Use a fine & sharp hack saw blade. I changed to a second new blade halfway through the shield.
http://www.youtube.com/watch?v=hQj05Db-C3c
