Cooler Running with 87 Octane???
Old Oct 5, 2008 | 07:56 AM
  #71
RollaMo's Avatar
RollaMo
Found this on a Sunoco web site:
Why is Sunoco gasoline different from other brands of gasoline?
* Sunoco gasolines meet every car manufacturer's specifications for oxygenated and reformulated fuels in areas where those fuels are required by law.
* Sunoco gasolines do not contain methanol.
* In compliance with federal law and as stipulated by most automobile manufacturers, Sunoco gasolines contain no more than 10% ethanol.
Source: http://sunocoinc.com/Site/Consumer/R...olineFacts.htm
Now, it does seem that some stations do have Methanol. This one is in Canada though.
Sunoco service station at 4061 Sheppard Avenue East in Scarborough, Ont., for consumer vehicle consumption.
The methanol is available via a special dispensing unit and retail pump for self-service fuelling, alongside traditional gasoline fuel pumps.
Source: http://www.allbusiness.com/north-ame.../327316-1.html
So, looks like it comes down to this:
If the pump says Methanol - Do NOT pump it into your Harley
If it says Ethanol - Although some won't use it, Harley says it is ok.
Old Oct 5, 2008 | 11:07 AM
  #72
Mac57's Avatar
Mac57
A lot of interesting debate here on the fuel/octane subject, but for me the manufacturer's recommendation trumps you all. The H-D manual specifically recommends 91 octane or higher. No matter what you think of the MoCo, they are the experts. Why mess around with theories?
Old Oct 5, 2008 | 11:18 AM
  #73
pete913's Avatar
pete913
Fact, any increase in octane over and above what the engine requires will make it run hotter, the reason being that a higher octane level does nothing more than make the gasoline burn slower. Any increase in power in an engine designed for, say 87 octane, that's being run on higher octane fuel is purely in the imagination of the operator.
Old Oct 5, 2008 | 01:10 PM
  #74
mp's Avatar
mp
They are? Their only motivation is to sell more bikes, and they say whatever they need to to accomplish that goal.
Old Oct 5, 2008 | 01:24 PM
  #75
mp's Avatar
mp
Originally Posted by Marksman
Speaking of ethanol. I have many boater friends who are very concerned about winter storing with ethanol gas in the boats. They have been citing information they have read that shows that the big problem with ethanol is that it breaks down. The end result is internal corrosion.
Seems like most stations in my area are 10% ethanol.
With winter approaching, I would think this would be an issue for many on this forum also.
Anyone heard of this?
Ethanol is highly corrosive; it can't even be pumped in the same pipelines as gasoline because it will eat through them. It also absorbs moisture, so it's a double whammy to leave it sitting in a gas tank over a cold, damp winter.
Old Oct 6, 2008 | 07:28 AM
  #76
Marksman's Avatar
Marksman
Not to hijack the tread away from octane, but thats what these boaters are concerned about. My buddy's have two tanks each holding over 100 gallons. The boats are early 1990s so they have rubber parts. I fact one guy just had both belt driven marine (expensive) fuel pumps fail. Have to wonder.
Easy for us to run run the tank out and fill with non ethanol fuel. These guys not so much. Sea Foam and hope for the best.
Old Oct 6, 2008 | 08:02 PM
  #77
Steve On 3's Avatar
Steve On 3
OK not so fast. I checked my owners manual and it says 87 octane is recommended. I had beem running mid or premium until the fuel shortage because I just felt it would be better BUT the 87 runs just fine. Course I am ridng a 95 Ultra with an evo. When I save enough on gas to buy a new bike, I think I'll pay cash for it. Only 2 million more miles to go . LOL
Old Oct 6, 2008 | 08:13 PM
  #78
Thumper09's Avatar
Thumper09
Oil is just like any other commodity.
When the price of gold rises, is it because there's a shortage?
The trading price of commodities are influenced by the market. Certain lobbyist try and use these fluctuations to help instill fear into Americans so they vote to change legislature into allowing them to drill in places they currently are not allowed, such as Alaska.
We will be piloting flying saucers long before we run out of oil.
"Free America from dependence on foreign oil" is slang for "We want to make tons of money so we have to do whatever it takes to convince the US people to let us drill for oil in protected land. Because we don't care about the land, or the people, we just want that new Mercedes that we just saw in Motor Trend last month"
That's exactly what it means.
Old Oct 6, 2008 | 08:42 PM
  #79
Ultra110's Avatar
Ultra110
The two real issues with Ethanol is one it has an affinity to water, meaning it will bind readily with water. This can be a good thing...AKA Dri-Gas. Problem being it can only bind with so much water. When it reaches the maximum capacity it has what is called phase seperation. In other words the ethanol/water mix phases out of the gasoline settling to the bottom, leaving behind a gasoline with a very low octane rating and an ethanol water mix, neither will burn easily if at all..
The other issue with Ethanol is it is a very strong solvent. Sloshing around in your fuel system will loosen and suspend any contaminents that have formed there over time. The problems we have in the marine industry are usually from older fiberglass tanks. The Ethanol actually degrades the resin that binds the older fiberglass. Newer resins have been determined Ethanol safe.
Newer fuel systems are not exactly always safe. Just replaced the fuel system in a '97 bike that had started leaking, fuel lines were found to be sticky and soft. Squeeze the line between your finger and thumb and it would flatten and stay stuck together. On a side note 10% Ethanol mix removes 10% of gasoline from every set volume and replaces it with 10% Ethanol (that has a lower BTU rating VS Gasoline) so you actually get less power per gallon of E10 than you do with straight gas. This will require you to 'give it more gas' to get the same performance and mileage will drop. (as a direct result of the BTU per gallon) Now do we bring up the whole issue of cetane ratings for diesel fuel?
Old Oct 7, 2008 | 10:59 PM
  #80
LH's Avatar
LH
Originally Posted by dhoward
Wrong.
Octane rating enhancing substances slow the flame front, resulting in a controlled burn.
Spontaneous combustion without being initiated by a spark, is pre-ignition.
Thanks for the third-grade Mr. science reference though.
Ya almost got it 100%.... It should read:
Combustion without being iniated by spark, is pre-ignition but still somewhat of a controlled burn and that's the pinging you hear. The danger is pre-ignition can lead to detonation which is the complete and spontaneous combustion of all the fuel, and that will destroy spark plugs, put holes in pistons and bend push rods...... and that's a bad thing.
LoneBone
Aug 18, 2013 10:48 PM
06Sporty75
Jul 8, 2013 02:22 AM
jfsgb
Shovelhead
Feb 22, 2013 06:29 PM
harris48cars
Jun 16, 2010 09:26 PM
Butt Ugly
Aug 29, 2009 04:12 PM
