Install Hand Grips
Old Dec 23, 2008 | 08:31 AM
2007ELECTRICGLIDE's Avatar
2007ELECTRICGLIDE
Default Install Hand Grips
How hard is it to install hand grips not heated. I have a 2007 Electric Glide Classic any help would be app thanks
Old Dec 23, 2008 | 12:19 PM
smudge's Avatar
smudge
Saw on another forum that using hairspray works. When wet it allows the grips to slide right on and then when it hardens it holds tight.
Old Dec 23, 2008 | 12:22 PM
mech8251's Avatar
mech8251
Only thing I have to add to that is be gentle with the throttle grip. If not careful you will break the brake light switch. Unfortunately I found out all too quickly.
Old Dec 23, 2008 | 12:35 PM
rrsjs5's Avatar
rrsjs5
Manuel first,Grips second
Old Dec 23, 2008 | 01:31 PM
Trailfndr's Avatar
Trailfndr
If you are using HD Grips, the instructions are very good. Took me about 30 min. the first time. At taht time, I did not have a manual, but the instruction sheet was very complete as to what to do.
Old Dec 23, 2008 | 01:37 PM
fishcop's Avatar
fishcop
Default Hand grips
Changed the grips on my heritage and it was quite easy. Had to slice off the old ones then the new ones slid right on but as was stated above easy on the throttle one, don't gorilla it or you could break the switch.
pheur
Aug 10, 2011 01:58 PM
parts eeter
Oct 14, 2010 06:49 PM
Rockindaddy
General Topics/Tech Tips
Apr 14, 2009 06:37 PM
Blacklion213
Jan 1, 2008 06:54 AM
huskers11
Jun 25, 2007 05:22 PM
