What version of Firefox are you running?
I am also using a Mac, with Firefox 3.0.5 and the HD theme installed just fine.
Version 2.0.0.20 I hit the install icon and it showed it installing, but the home page didn't change. Am I missing a step or do I just need a later version? Thanks, Geezer
Check your Firefox preferences, to see if it's really installed.
Top menu bar: Firefox > Preferences
Make sure the "Main" tab is selected at the top of the window that opens.
Then at the bottom of that window, select "Manage Add-ons"
In the window that opens, select the "Themes" button at top of window.
Now, if the HD theme installed correctly it should show up here. If it does you should see a "Use Theme" button. Click that and you should see a message at the top telling you that Firefox needs to restart in order to use the theme.
If the Theme is not available in the Themes window, then something didn't work during the install. Try to install it again.
