Help finding an informative past reply to post
Old Jan 18, 2009 | 01:36 AM
chromedome's Avatar
chromedome
Default Help finding an informative past reply to post
Someone had cut the rear brake pedal mounting base to make the Mark III"s a bit roomier (allowed the pedal to move to the left a bit) It was mentioned in a reply to a post and I can't find it anywhere. Anyone recall this? What was used to cut the mount? How much of a cut?
Old Jan 18, 2009 | 03:03 AM
RiverWolf's Avatar
RiverWolf
Always try SEARCH first, so as not to **** off the old timers.
When using SEARCH, make it as brief as possible.
Use only words directly related.
CAP all related words, such as:
"Street Bob AND Turn signals AND relocate"
In your case you may need to keep reposting till the people see it.
Good kuck.
Old Jan 18, 2009 | 07:11 AM
LucklessPedestrian's Avatar
LucklessPedestrian
I don't remember seeing it, but this is the sort of mod I would hope see make it to the new Knowledge Base.
Old Jan 18, 2009 | 09:14 PM
chromedome's Avatar
chromedome
Good kuck.
Did that. This was a reply to a post and not a post itself. One of those things that you come across while looking for someting else and then later you say to yourself " I remember reading something about.." Ah well.
Old Jan 18, 2009 | 09:45 PM
sonar_chris's Avatar
sonar_chris
I don't have your answer about how much to cut, but I would recommend the Harley Goodies floorboard extensions http://www.harleygoodies.com/. They will move your floorboards out away from the bike and give you all the room you need on those MK III's. Here is a pic of my set up with those extensions.
Old Jan 19, 2009 | 09:34 PM
chromedome's Avatar
chromedome
sonar chris
sometimes you get so fixated on one thing that you miss the obvious. So thanks for your post. I have a set of Harley Goodies and took them off when I put on my engine guard. Dug em out and they'll do the trick.
Old Jan 19, 2009 | 11:09 PM
sonar_chris
Glad I could help.
jetfixer62
May 4, 2014 11:05 AM
acd118
Welcome Area Only
Jun 2, 2011 08:53 PM
mazman
Apr 6, 2009 12:48 PM
Streetrunner
Jul 17, 2008 07:10 AM
anubisss
Nov 7, 2006 10:54 PM
