Spot lights
Old Apr 12, 2005 | 12:00 PM
billnourse's Avatar
billnourse
Default RE: Spot lights
I run mine all the time as does my wife. I had one fail on my Roadking after about 50,000 miles. That's the only failure we've ever had.
Regards,
Bill
Old Apr 12, 2005 | 12:24 PM
12Stones's Avatar
12Stones
That's some good info. Thanks for sharing.
Old Apr 12, 2005 | 12:41 PM
Harley Rulz's Avatar
Harley Rulz
I run mine all the time for the same reason as everyone else (I like thinking I can be seen easyer by cages) and I'm gonna make the wireing mod as soon as I get home tonight.Thanks for the info Amused.
Old Apr 12, 2005 | 04:56 PM
Longhair4life's Avatar
Longhair4life
Well, I want to ride with the spots on all the time but i was just wondering how it would effect the battery or lights. I just installed Adjure jeweled tri bar spots and head lights yesterday. Anyone else runing these lights?
Old Apr 13, 2005 | 02:13 AM
nmfxstc's Avatar
nmfxstc
NO need to change the fuse! Any hot wire will worek to allow both high and low beam operation...have mine that way and no probs!
Old Apr 13, 2005 | 04:17 AM
John TN's Avatar
John TN
I run my spots all the time, for two reasons. One for more visibility during the day and two, I have my spots seperate from my headlight and if at nightime my main headlight bulb should blow, my spots would still give me ample light to see where I'm going.
John TN
Old Apr 23, 2005 | 01:50 AM
AceArt's Avatar
AceArt
This was from a while back, but I'm getting ready to do this and realized that I had a question which I forgot to ask: On the mod, what happens to the yellow wire out of the headlamp connector?
On the original, it shows it coming from the headlamp connector to the passing lamp switch.
On the modification it only shows it coming out of the passing lamp switch. Does it still run from theheadlamp connector first or do you just remove it from the headlamp connector for the mod?
TIA for any help. I'm still amazed and can't understand how lights come on when I turn a switch, so thought I'd better double check this. Art
ORIGINAL: Amused
How to make your passing lamps stay on when your brights are on:
[IMG]local://upfiles/880/8036DFD40C384D57B0426B270A5894B5.gif[/IMG]
Old Apr 23, 2005 | 02:51 AM
John TN's Avatar
John TN
Aceart,
The passing lamp hot wire to switch is originally fed from low beam hot wire. On the mod you will remove the passing lamp 12 volt feed from the yellow 12 volt headlight wire, and go to the accessory hot wire to get 12 volts back to the passing lamps. This eliminates the passing lamps from the lowbeam and allows them to be turned off or on at your choice.
Old Apr 23, 2005 | 03:01 AM
AceArt's Avatar
AceArt
Thanks John! Art
Old May 27, 2005 | 06:52 PM
MoesSS's Avatar
MoesSS
Where is the best/easyest place to tap into the orange/red wire?
