Cig Lighter socket?
Old Jun 14, 2009 | 08:52 AM
PPBART's Avatar
PPBART
Default Cig Lighter socket?
CORRECTION to my original post -- it's a J&P Cycles item, link below...
http://www.jpcycles.com/Search/Produ...rch&results=10
Old Jun 14, 2009 | 09:01 AM
PPBART's Avatar
PPBART
OK, that's weird... I posted a msg, saw an error, reposted with correction, now the original disappeared(?)
Anyway, I was talking recently with some buddies about taking a road trip next month, and one guy just went on and on about how I should take an inflatable mattress and 12V air pump. He has a cigarette lighter socket strapped to the frame, kinda sloppy-looking setup (but it obviously meets his needs).
I was interested enough to do some checking and found the unit a J&P Cycles. Not sure just where I would mount it on the Deluxe, but would use it for occasional GPS, cell-phone charger, air pump, etc. I'm always leery of cutting into the wiring harness, this just has one-wire connection to battery.
Anybody use similar add-on unit?
Old Jun 14, 2009 | 09:20 AM
ibhsffo's Avatar
ibhsffo
You can get a weatherproof one from WalMart or AutoZone for around $20.00 but they have a zytel or some other synthetic housing. They are black and would be easy to hide. I do like the look of the J & P unit, but that seemes a little high for a lighter socket.
Old Jun 14, 2009 | 11:54 AM
SgtMic's Avatar
SgtMic
Old Jun 14, 2009 | 12:22 PM
krub6t9's Avatar
krub6t9
are you could try this one from powerlet. it hooks into the battery tender plug.
http://www.powerletproducts.com/prod...ket-cables/319
Old Jun 14, 2009 | 01:57 PM
PPBART's Avatar
PPBART
For no more than I expect to use it, that's certainly the simplest solution I've seen so far -- and for less than $20(!) Has the added benefit of making use of what's already there (tender connection) without any more putzing around with the wiring haress.
Old Jun 14, 2009 | 04:50 PM
electricstart's Avatar
electricstart
Thanks ,Going to get one myself.
Old Jun 14, 2009 | 07:13 PM
cactus789's Avatar
cactus789
Thats exactly what I'm looking for!! I went to my dealer the other day and they had no clue, " They don't make Cig plugs that plug into your battery tender".... Clueless!!
THANKS
Old Jun 14, 2009 | 07:21 PM
SgtMic's Avatar
SgtMic
THANKS
And that surprises you?
Old Jun 14, 2009 | 07:30 PM
HammerheadC4's Avatar
HammerheadC4
I've been using this one http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
I mounted it on the stud used for the horn and ran the wires under the tank with an inline fuse directly to the battery.
