for the left turn signal switch. I tseems that the gear that turns when the siwth is pushed in is partially broken on my ride. Is it possible to just get the button and gearing that goes inside the left switch housing? Sometimes it works and others it does not. Thanks.
Hey Anubisss, what year bike? I think 99 is the year they went to the more rounded switches. I can't get a number until tonight when I get home from work, but I'll look if nobody beats me to it.
Oh, and I don't think you can order the internals of the switch separately, but you might be able to take it apart and find the parts at an Ace Hardware or similar.
Oh no, sorry if I wasn't clear. You can order just the switch. You'll have to remove the old one from the lower switch housing, de-solder the connections and then solder the new one in. There's just a small screw holding the switch in place.
I thought you were asking if you could repair the switch itself.
