Engine Braking Sucks(?)
1. The act of reducing your speed (either by using your brakes, or your drive train) requires
the body in motion (your scoot) to lose momentum. The brakes accomplish this with
friction (which generates heat and wear on the brake pad). Engine braking is not a free
lunch either (Their isn't one). It generates wear on the drive train. It can even generate
more force on the drive train (Depending on speed/load/distance/time) than the engine
does.
2. Several folks have attempted to draw a comparison between bikes and 18 wheelers.
There is a reason the Jake Brake was invented. Trucks can have too much load for
brakes to stop them without overheating. A Jacobs Engine brakes uses compressive
force in the cylinder to slow the truck. That saves wear and tear on a drive train.
3. During normal riding conditions your brakes (which happen to be less expensive & easier
to replace than any component of your drive train) are very capable of stopping your
bike.
In closing...yes normal riding generates wear on your drive train as well. I'm not sure how
that was "part of my logic". It is in fact true...I was just speaking about the wear of
braking. In any case, you're more than welcome to jam your throttle WFO...max out the
gear...and back off if you like. It'll make some big noise for ya. I just chose not to.
-clutch-
OK, so we agree that normal riding such as accelerating or maintaining a steady velocity against the normal and various resistances to forward motion pose a wear and tear element to the drive train, and so does engine braking. Where I was being cute was in disagreeing with your assertion that engine braking under normal riding conditions constituted an excess wear and tear on the drive train. I contend that the drive train is engineered and designed to be well within normal operating parameters with engine braking under normal riding conditions. Furthermore, the amount of reverse load borne by the drive train under engine braking conditions is primarily a factor of the degree to which the reciprocating and rotating drive train components are resisted in their deceleration by the mass and momentum of the bike. The engine and other drive train components want to inherently slow down during engine braking due to their internal frictional losses, while the forward momentum of the entire bike including the drive train, occupants, and luggage conspire to try to keep the thing moving. Again, I contend that in so doing, under normal riding conditions, the drive train is operating within its design specifications, and therefore, the amount of wear and tear sustained is no excessive.
Now then, when do we set up that video shoot, then you owe me a few cold ones over at Norma's or Coaches, and a trailer lift back home
-clutch-
I think he must have been in one of them wrecks you talked about...cause from where I'm standing I heard him say, "uh eh 2 dogs um er fried taters movin speed"...what's hard to understand about that???
-clutch-
