primary oil change help please.
Old Aug 12, 2009 | 12:12 PM
dastark's Avatar
dastark
Default primary oil change help please.
I'm changing my primary fluid for the first and the manual says 26 ounces. However 26 oz. doesnt bring the level up to the bottom of the clutch diaphram. I've got a quart in there now and still not full. Help please? It's a great day and I want to get back on the road.
Thanks.
Old Aug 12, 2009 | 12:14 PM
mcouture's Avatar
mcouture
What year? What model?
My '09 takes 38 oz ....
Old Aug 12, 2009 | 12:22 PM
dastark's Avatar
dastark
05 S.E. Fatboy. Thanks for the reply. My manual's not S.E. specific.
Old Aug 12, 2009 | 12:29 PM
mcouture's Avatar
mcouture
With my limited knowledge on the subject I would assume the oil level should be like you said....
Old Aug 12, 2009 | 12:35 PM
anubisss's Avatar
anubisss
I just put the 26 oz's the manual calls for. I have never had a problem.
harleydavis's Avatar
harleydavis
Fill it until it touches the bottom of your clutch diaphragm spring. The 26 oz. figure you referred to is an approximation.
Old Aug 12, 2009 | 12:54 PM
Juve996's Avatar
Juve996
The fluid levels are not an approximation, you need to stick to what the manual calls for. Your finger is NOT a calibrated dip stick for checking fluid levels. If you overfill the primary case the clutch will give you problems and not work correctly. If it says 26oz, put in exactly that, no more no less. Most fluid containers you buy have a volume window on the side of the plastic container so you can make sure you get the correct amount in whatever you're filling, use it..
Old Aug 12, 2009 | 01:00 PM
oct1949's Avatar
oct1949
I know I keep saying this, but do a search for Ur bike on this, there are plenty of web sites to help and show u how to do it....
Old Aug 12, 2009 | 01:51 PM
Slowpoke84's Avatar
Slowpoke84
Then what's the point of this site if we just Google everything and look elsewhere?
Old Aug 12, 2009 | 01:56 PM
oldairboater's Avatar
oldairboater
Is the bike straight up and level?
