Turn signal relocation-Tank lift-Pics
Old Jun 2, 2006 | 02:31 PM
TOMMAY's Avatar
TOMMAY
Default Turn signal relocation-Tank lift-Pics
I know these pics are too big.I reduced them to one fourth size,I thought.
SE intake. I was running the open element with Harley cover on just the center. Found this ol Panhead cover which I like but I wonder if it's overly restrictive of air flow,only has about 1/4 in. clearance from the filter element. Seems to run ok though.
Started out with the Harley relocation kit down on the clamps with those big ol honkin' stalks,like this a lot better.Royal PITA to install.
Home made tank lift.3/4 in. flat stock and alum tubing from Home Depot.
Old Jun 2, 2006 | 08:50 PM
phreak's Avatar
phreak
Default RE: Turn signal relocation-Tank lift-Pics
Are those the Kuryahkn clamps?
Got one side of mine installed last night. I'm liking the look of the clamps much better then the pinch bolt things.
Old Jun 2, 2006 | 08:59 PM
TOMMAY's Avatar
TOMMAY
ORIGINAL: phreak
Yeah,Kuryahkn's.Hope it went faster for you than it did for me,those connectors gave me fits.Ended up cutting and soldering on one side.
Old Jun 3, 2006 | 03:13 AM
phreak's Avatar
phreak
Well, I decided that this would be the perfect opportunity to go ahead and run the wiring inside the bars too.
My 13 YO son helped me, and we got one side done in about 3.5 hours. We cut and spliced everything. Extended the control wiring, and took the excess out of the turn signal wiring.
Also spent some of the time teaching him to solder.
Old Jun 21, 2006 | 01:45 AM
jmbear328's Avatar
jmbear328
Hey Phreak,
Thanks to you guys on here, I just couldnt wait any longer. I ordered me a set of the Kuryakyn fork mounts as well,... I also ordered me a new chrome headlight assembly. I was thinking of running my wires through the bars as well. I figure that moving the signals, installing the headlight assembly and rerouting the wires through the bars would be a good Sunday project.
John
heathergrasby
Jan 12, 2018 07:30 AM
Misbehaven
Jan 10, 2017 05:47 PM
SARGE14
Feb 5, 2011 02:26 PM
ski917
Jan 1, 2010 06:17 PM
locknload
Jun 16, 2006 11:39 AM
