replacement speakers
Here is something to keep in mind...
Specs say stuff like 88db @ 1 watt 1 meter...
This means the speaker produces 88 decibels at 1 watt of power , 1 meter away. The higher the db at 1 watt/1m means a more efficient speaker.
In laymans terms a speaker rated at 93db will rock your *** off at the same volume level setting on the **** compared to a 87db speaker. It will seem twice as loud. Buying higher rated speakers allow you to get more sound with less amplifier.
If I know Harley riders, they like pipes, and be able to hear the radio too.
You should be able to buy better speakers than hog tunes for $100.
who did you get the arc`s from?? no warranty??
how did they go bad?
sometimes my tweeters seem to go down in output then back up again.
thanks for posting!! it is hard to explain that to someone. everyone thinks in watts only. here is a funny fact
klipsh horn speakers have a efficiency ratting of 104 and only need 65 watts to produce a spl of 110 and the same speaker in 88 efficiency ratting requires i belive it was like 1500 watts
One thing that has come to mind is all the rain I have rode in over the last three months. Actually we came though a terrible storm with heavy rain a day before the first speaker failed. Then we had nothing but rain at the state rally and the bike had to sit outside in the rain the whole time. I wonder if those speakers could not hold up to the weather?
Shakey
lets see
88 vs 104
88,91,94,97,100,103,106,109
1, 2, 4, 8, 16, 32, 64, 128 watts to break 109db if my math is right.
spl on my infinity speakers...
95,98,101,104,107,110,113
1,2,4,8,16,32,64
113db at 64 watts. max is 75 watts, so maybe 114db? max
Thanks... TL
Thanks,
