Heated hand grips
Old Sep 9, 2009 | 12:19 PM
cadman311's Avatar
cadman311
ESP warranty will not help you on HD heated grips if you ride in the rain.
Old Sep 9, 2009 | 12:56 PM
barjbar's Avatar
barjbar
I have them on both my bikes. When it gets very cold, below 30 degrees, their effectiveness is minimal - my bikes don't have fairings to protect the hands. I purchased heated gloves They will literally burn the skin off my hands so I also purchased the temperature regulator. So I use both depending on the outside temperature.
Old Sep 9, 2009 | 01:38 PM
bmwrick's Avatar
bmwrick
Default Harley Davidson Heated Grips
I have a 2009 FLHX, had the grips installed when I bought the bike, loved them. I've had to replace 3 times since, the dealer says they never last, I'll keep changing them since they are under warranty, but what a pain in the a$$! Love them, but why can't Harley do it right?
Old Sep 9, 2009 | 02:05 PM
Ribaldmanikin's Avatar
Ribaldmanikin
A friend of mine has some installed on his 04 Fatboy, and raves about them. He's never had a problem. I thought I'd take his advice, and get a set.
Unfortunately, the local dealers won't even stock them anymore because of the problems.
Old Sep 9, 2009 | 03:57 PM
Simon UK's Avatar
Simon UK
Thank you to all who have responded for your input. As I live in the UK, riding in the rain is a regular occurence, so it sounds like the H-D grips may not be too good. Maybe I'll have to go the heated glove route instead. I'll also check out the internal handlebar heaters that were mentioned favourably above.
Old Mar 29, 2012 | 04:42 PM
AT98VIKING's Avatar
AT98VIKING
Stage IV
Unhappy Heated Grips
Originally Posted by cadman311
HD grips I have had them go bad three times last year. Harley dealership told me I can not use my bike in the rain if I use heated hand grips. I now use heated gloves much better.
I've had the BMW heated grips on two bikes - NO problems and accomplished their purpose---
However, I've got the heated grips on the 2011 CVO Road Glide and they DO NOT function correctly below approximately 40-45 degrees - which is when you NEED them. Apparently, the ambient air temp in that range negates the intent.
The dealer tried their best to fix the problem but their hands are tied after try #3, when the motor company has to be conferred with.
They do what the H-D Tech says to do, and I go down the road as the guinea pig and get frosty hands.
I called their CS people and they called back saying that the grips check within parameters in the shop, so they won't be able to take any further action.
Hellooo!! Wrong environ dufus...
I paid for an accessory that isn't worth spit and they won't back the product.
BTW - I am one of many who have had this scenario bite them and no relief offered....
It's your call.
I'm going back to the Gerbing Heated Gloves and H-D can bite me.
Ooops - did I say that out loud?
Old Mar 29, 2012 | 05:45 PM
williamfrog's Avatar
williamfrog
Talking
Originally Posted by Ridewva
Terry, to an extent you're right regarding the grips warming your palms instead of the back of your hands. But here's my take on their usefulness. When you start getting even slightly chilled, for instance riding in the rain when it's cool, your body starts reducing blood flow to your extremities. Holding on to something warm seems to reverse this and you actually feel warmer all over, not just your hands.
BMW has been offering heated grips for years and some models even come standard with them. I first had them over 20 years ago on a BMW. I'll put it this way, heated grips certainly aren't a necessity and if you've never had them you won't miss having them. But once you get used to them you'll be spoiled.
What he said. I have the Heat Demons,they work well.
Old Mar 29, 2012 | 06:13 PM
spelk3's Avatar
spelk3
I use poly heaters, they fit inside the handlebars. You can use any grips you want since they heat the bar not the grip. They only have two settings (high or low) but that is enough. They work great and I have no problems with them in the rain.
If you do get poly heaters make sure you get the ones for motorcycles, not the ones for snowmobiles.
Old Mar 29, 2012 | 06:24 PM
Ratkiller's Avatar
Ratkiller
I have them, dealer installed at the time of purchase on my 2008 UC. No problems what so ever. They work great. Glad I have them. Must have been one of the lucky ones.
Ratkiller
Old Mar 29, 2012 | 06:25 PM
fat_tony's Avatar
fat_tony
http://lockitt.com/Lockitt/category/ELGPHG.html
Heated grips are great in cooler weather with insulated (non perforated) gloves down to about ~13C/55F. If you ride in conditions colder than this though I would recommend heated gloves instead - they warm the fingers and back of hand, the parts that get the most chilled.
