Uneven Lanes Question
Old Jun 26, 2006 | 04:43 PM
SPRINGER's Avatar
SPRINGER
Default RE: Uneven Lanes Question
Interesting that you should bring this up because when I bought my Harley last year, I encountered that problem 3 times in one week. I took a week off to enjoy my new Harley and I went 3 different directions and they were working on the road in all 3 places. I really didn't want to embarrass myself in front of everybody, so I just took a firm hold on the bars and took it at about a 45 degree angle, like others have said. Needless to say, I didn't go back over those same roads for awhile until I knew that they were done working on them. Hope this helps.
Old Jun 26, 2006 | 05:09 PM
Jenny8675309's Avatar
Jenny8675309
In the MSF class they tell you to wait til you get to a bridge since they don't grade them. But the best is to try to avoid them. Our instructor told us that he takes the long way around in order to avoid that if possible.
Good luck,
Sue~
Old Jun 26, 2006 | 05:22 PM
whaap's Avatar
whaap
It's do-able but not safe. Slow, cross as close to 90 degrees that you can (atleast 45) and hold the bars tightly. Did I say SLOW?
Same applies to rail road tracks and, here where I live, cattle guards. Tracks and cattle guards are also dangerously slippery when wet.
Old Jun 26, 2006 | 05:54 PM
Keith_H's Avatar
Keith_H
Yeah, i'm not feeling real froggy about this whole thing.
It wouldn't be so bad but they didn't even out my on ramp so i'm stuck with it everyday. Hopefully they get it fixed. Now i'm reduced to getting to the bottom, stopping, waiting for a break in traffic and hitting it head on and then screaming on up to speed (i'm out in the middle of rural nowhere I-70, no other traffic behind me on the ramp). It works but thought i would ask the question. Thanks for all the great input, didn't want to hurt the bike, and oh yeah, me too. Nothing else spooks me, not smart enough to be spooked, but this had me concerned.
I guess i'll take the knowledge on how best to do it if i have to but avoid it all all costs.
Old Jun 26, 2006 | 06:19 PM
SamStone's Avatar
SamStone
It happened to me a few weeks ago at night on a crowded highway in a construction zone. The uneven pavement came angling into my path with a car next to me. It was either make it or get pushed into the car next to me. I made it. I think everyone should practice that in safer conditions.
Old Jun 26, 2006 | 06:58 PM
TampaJim's Avatar
TampaJim
I agree, RR tracks are very dangerous.
Something else that scares me is those painted (white or yellow) lines when it is wet. Some of our local road maintenance folks lay it on thick and it can get really slick.
More than a few times I have lost traction when turning at an intersection --usually early in the morning when there is dew .
I try to give those lines a wide margin.
Old Jun 26, 2006 | 11:04 PM
NoVaThunder's Avatar
NoVaThunder
ORIGINAL: TampaJim
Very UNSAFE!!! It's called an EDGETRAP If the difference is abrupt it can catch your front wheel and guide it along the edge, jerking the handlebars out of your hands.. Happens so fast you can't correct and it's kiss the pavement time..
If you absolutly have to cross uneven pavement, slow down, get a very sharp angle (45') and make sure you have a good grip on the bars.
Fat tires probably have an advantage over the skinny ones in this situation.
I'm going to have to agree. I sit here with a broken knee out of work for 3 months. I was coming across a concrete bridge bout 11:30pm, and was beginning a lane change as I got to the end of it. They had milled the road beyond the bridge, no signs, no cones, no workers. As I began the lane change I looked over my shoulder to check for traffic. As I turned my attention forward I caught a flash of the milled pavement out of the corner of my eye, my backend fishtailed violently, and I was on my a@#. (Just like Tampa said). Buddy behind me said he saw the lip as my rear tire bounced off it the first time. He had already completed his lane change on the bridge as he was offset on me. I have ridden over many of these milled areas in my life and never had much of a problem. That shows you what can and will happen if your angle on these things is too gradual. He took some pictures of the pavement so he could show me. It was over a 3" difference between the lanes. That probably would have been interesting to try to negotiate even if I had known it was there.
Chuck
Old Jun 27, 2006 | 12:01 AM
goodbirds's Avatar
goodbirds
angle and aggressive approach is the key. I usually hit them at about 30 degrees with a rapid change in direction toward the higher level. The tires get traction and climb the edge quickly. Works every time.
Old Jun 27, 2006 | 01:17 AM
Rockies Rider's Avatar
Rockies Rider
NoVaThunder, Milling highways is what I do for a living. If the regulations in VA. are anything like out west, there should have been a contractor buying you a new bike and paying all your medical bills.
Old Jun 27, 2006 | 01:38 AM
thumper 29's Avatar
thumper 29
Yep those ain't fun, I don't even think I would try to cross one of those in the rain.
But everyone is right, just take the furthest area of the lane you are in, firm grip on the bars,
and shoot into the grade change as close to a right angle, which will be about a 45 degree angle
of attack.
I don't like those anymore than anyone else, and if possible try and avoid them altogether.
There have been some instances I have either turned around, or just stayed in the lane I am,
and if traffic starts to force me to change I have pulled off the road and waited for a clear
shot in order to change to the higher area. It ain't worth messing you or your bike up if
you can help it.
