Bike won't start
Old Nov 20, 2009 | 04:48 PM
oldairboater's Avatar
oldairboater
You posted the engine won't turn over and you posted that it just turns over and over without starting. Your posting that you changed out parts but not why you thought you needed to change them out. It is a four stroke engine--it needs ignition, timing, fuel, compression and exhaust. Check voltage to the coil. Do you have 12 volts going into the coil? Do you have fire to the spark plug? If not find and fix the problem before changing parts out. If you have fire to the spark plug------next do you have gas getting into the cylinders? If you do ---then that leaves timing, compression, and exhaust. Got a repair manual specific for you bike? If not spend some money on that before anymore parts change outs.
Old Nov 20, 2009 | 05:50 PM
WWECOUGAR's Avatar
WWECOUGAR
+1 Very well said.
Old Nov 20, 2009 | 05:57 PM
MidnitEvil's Avatar
MidnitEvil
Yeah, I'm confused on whether it's cranking and not starting, or not cranking at all. Can you clarify that?
I'm also unclear as to why you're changing out parts.
Old Nov 20, 2009 | 07:26 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The first post sez the engine turns over, then post #9 sez "it just won't turn over". Did you pull the plugs and spin the engine to see if the plugs are sparking? Did the bike start okay on the last ride? If the bike isn't starting or turning over then check the security fuse.
Old Nov 20, 2009 | 07:29 PM
Other Sheep's Avatar
Other Sheep
Did you check the turbulator and the franken plugs?
Old Nov 20, 2009 | 07:37 PM
2003Springer's Avatar
2003Springer
Originally Posted by Q ball
I replaced relay fuse, ignition circuit breaker, coil and crank sensor, I checked for damaged wires, I'm getting gas, but it just won't turn over, the engine light is not coming on before I start the bike
1st post you said it cranked but would not fire (start) this post it won't turn over? If it won't turn over it has a dead battery. 99.9% of the time. Sorry I cann't help more than that
Old Nov 20, 2009 | 07:44 PM
Wallaby's Avatar
Wallaby
NFI, sounds like you have a cranking, but not firing, now not cranking bike?
As someone infinitely wiser than I once said to me "Seek professional help.."
Old Nov 21, 2009 | 06:35 PM
MidnitEvil's Avatar
MidnitEvil
There's no way it could be the franken plugs dumbass. He says it's not turning over and it cranks but won't start. Does that sound like the freakin' franken plugs to you?
Old Nov 21, 2009 | 07:26 PM
Other Sheep
Sorry, my mistake. It would be the franken plugs if it was cranking but not turning over. Gotta read better next time. Try the histamonic elabutom instead.
Old Nov 21, 2009 | 09:19 PM
2kids3pets's Avatar
2kids3pets
You would think if the OP had a real problem he would be back in here quizzing the guys in the know...guess he ran out to get some more parts..lol
