Check your engine oil...
Old Nov 29, 2009 | 03:45 PM
xxxflhrci's Avatar
xxxflhrci
Originally Posted by schumacher
I check mine cold. If there's any on the stick, it's fine
Me, too.
Old Nov 29, 2009 | 04:57 PM
jcghound's Avatar
jcghound
I agree. Checking oil is not rocket science.
Old Nov 29, 2009 | 06:23 PM
Gray_Drifter's Avatar
Gray_Drifter
With a softail, you really need to check the oil when it's hot with the bike straight and level. If the bike's been sitting for a few days or more, chances are some of the oil has drained down into the sump and if you check the oil when it's cold, it will appear low when it's really not. It's perfectly fine to check the oil when it's cold, just don't add any oil based on what you see. With my Fatboy, the oil level will be about half way between add and full when it's cold and only been sitting for one or two days. If the bike's been sitting for a week or more, more often than not the oil will be barely touching the dip stick if I check it cold. If you think you need to add oil, make sure you take the bike for a warm up ride first and then check the oil when it's good and hot. That's the only way you can be certain what the true level is.
Old Nov 29, 2009 | 07:05 PM
2003Springer's Avatar
2003Springer
Originally Posted by CroK
combustible engines ALWAYS run best just before they BLOW!!!
That's called the calm before the storm or the chit is about to hit the fan
Old Nov 29, 2009 | 07:34 PM
Apex Rider's Avatar
Apex Rider
I have what might be a dumb question on oil changes....
On my cars I get the oil up to tempt before changing to help suspend the junk in the oil.
Is that a good idea on my scoot or is doing it cold acceptable ?
Old Nov 29, 2009 | 07:38 PM
Jim Gumbel's Avatar
Jim Gumbel
I bought an electronic dipstick. (with the 09 part number, the 07's are no good) I check mine everytime I ride. It is wonderful. I love. I have heard of people who don't. But is sure easy to check. Just a push of the button. Ride on Dudes and Dudettes!
Old Nov 29, 2009 | 07:48 PM
Cheater's Avatar
Cheater
I've wondered that myself. Seems to me if the oil had all settled to the bottom of the sump you'd get more old oil out, right? So I tried it on the last oil change and it took hours to drain. Now I'm back to warming it up before draining.
Old Nov 29, 2009 | 09:33 PM
marc the shark's Avatar
marc the shark
THis is complete rookie question on my end but what would "too much oil" do? And and what point is it considered too much??
again I apologize if its a dumb question but I'm a newb and I must start somewhere...
Old Nov 29, 2009 | 10:01 PM
oct1949's Avatar
oct1949
read the manual. It says to ckeck it every time U ride...............
at least monthly...................If U ride 100 miles a month
not Yearly......................
Old Nov 29, 2009 | 10:41 PM
old skool1983's Avatar
old skool1983
unacceptable!!!! always change your oil hot
