It Happened While It Was Hot!!!
Old Jul 13, 2006 | 10:57 PM
geo10's Avatar
geo10
Default It Happened While It Was Hot!!!
Ok so I just wanted to wipe off some crud on the exhaust... so i grabbed a towel and tried to clean the crud off but the exhaust was still too hot. It burned some of the towel right on the pipe. In a panic I tried to wipe off the burned towel with the towel again and made it a little worse. Is there anything that I can use (metel polish or something) that will help get the burned towel fibers off of the pipe?
Bones
Old Jul 13, 2006 | 11:00 PM
blueduece's Avatar
blueduece
Default RE: It Happened While It Was Hot!!!
oven cleaner
Old Jul 13, 2006 | 11:05 PM
collin's Avatar
collin
I use PVC primer to remove anything that burns on the exhaust, it comes with a soft swab in the can and is formulated to dissolve plastic
Old Jul 13, 2006 | 11:11 PM
needaz's Avatar
needaz
ORIGINAL: blueduece
oven cleaner
oven cleaner????
will that hurt the pipes?
I have something that burned on the pipe and I need to get it off also.
Old Jul 13, 2006 | 11:13 PM
Mr Wonderful's Avatar
Mr Wonderful
First of all let the dang thing cool off to cold. Get the area as wet as possible and take as much of it off with soap and water and a rag. NEVR-Dull is a metal polish that is impregnated cotton wadding in a can. You can buy the product at most auto parts stores. Rub the area with a little of this wadding and it should take everything off. Great for burned-on rubber from your boots. etc.
Always wash your bike when it is cooled off.
Old Jul 13, 2006 | 11:18 PM
zombie's Avatar
zombie
Nevrdull or brasso works for me.
Old Jul 13, 2006 | 11:44 PM
boom215's Avatar
boom215
when my girl burned some rubber from her sole on the pipe, i actually warmed it up and found a real hard peice of plastic and swipped it off.
Old Jul 13, 2006 | 11:49 PM
Punky Brewster's Avatar
Punky Brewster
ORIGINAL: blueduece
oven cleaner
What bkueduece said,,,get the pipes nice & hot & spray oven cleaner then wipe down,,,,,you may have to do it a few times but works real good
Old Jul 14, 2006 | 12:37 AM
straitshot151's Avatar
straitshot151
nail polish remover works well for me.The wife probably has plenty
Old Jul 14, 2006 | 12:40 AM
daddiokool's Avatar
daddiokool
Oven cleaner worked for me!! Had polyester on pipes and mufflers ... and I didn't feel a thing ... what a maroooon I am ..lol
One thing to keep in mind though .. is block off the engine if you can with something ... because that spray goes all over the place! I used Easy Off cleaner .. with the pipes hot ! Did it twice and the polyester was gone.
