Twin cam ?
Old Jan 18, 2010 | 01:08 PM
o/d's Avatar
o/d
Originally Posted by terrysillik
Thought i would bring this back to the front, any body have any help on this question? terry
as far as i know, "b" is the balanced engine -as found in softail models.i beleive "a" is the un-balanced motor.i would *** ume that the serial # would tell you what year it is.
Old Jan 18, 2010 | 01:18 PM
DGDyna's Avatar
DGDyna
You might want to bring this up in the Dyna forum. A lot of knowledgeable guys there.
Old Jan 18, 2010 | 02:03 PM
oct1949's Avatar
oct1949
Is the A the early one and the B the later one? How do you tell which one you have, by the year of the bike or is there something in the seriel no.? terry
"A" motors is what the Dyna's and touring bikes use, rubber mounted, when the TC 88's came out in the softails, they balanced the cranks making them smoother (non-rubber mount). Thus the B motor.
Old Jan 18, 2010 | 02:11 PM
cadman311's Avatar
cadman311
The (A) motor hangs the rear swing arm and wheel off the trans. The (B) motor are the motor with the oil tank on the side. The (A) motor oil is in the pan.
Old Jan 18, 2010 | 02:37 PM
legacycycles's Avatar
legacycycles
Oops
All "B" engines are softail Solid mount only.If the engine is outta the bike,the "B"Engine is phyically bigger on the bottom.This is where there is about 20lbs of Sh$% spinning around in the bottom of them...."A"engines are in everything else,which are all rubber mounted."A" Engines when outta the bike look more like the typical V-Twin engine...Year models can be identified by the vin number on the engine also.
Old Jan 18, 2010 | 03:16 PM
Harley_Dude's Avatar
Harley_Dude
No, the A motor is rubber mounted (Dynas & Touring), the B is balanced and rigid mounted (Softails). The cases are different.
Old Jan 18, 2010 | 06:59 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
From everything I've read about the Magneti-Marelli EFI system, which was/is on the early twin cams, they had a lot of problems. One thing in mind comes to not helping the engine produce the horsepower a stock engine could. Just tweak your carb engine.
Old Jan 18, 2010 | 08:06 PM
nighttrain72970's Avatar
nighttrain72970
Yeah, what OCT said!!!
Old Jan 18, 2010 | 08:17 PM
wescoot2's Avatar
wescoot2
If you can see the engine, the above is the key to knowing if it's an A or B motor.
Unclescarhead
Jan 25, 2024 09:12 PM
23Seven
Nov 6, 2018 08:00 PM
mshred
Apr 18, 2018 07:59 PM
Hester
Apr 29, 2008 12:43 AM
99night train
Nov 26, 2006 04:49 AM
