Good CV carb?
Old Feb 17, 2010 | 08:16 PM
Failz's Avatar
Failz
I don't remember which jets I'm running but they could do for another change...again. I'm running a A/N Big Sucker, SE Heads, Dyna 2000 ignition, and Thunderheaders. I feel a larger/better carb will only help. Especially since a cam and higher compression pistons are in the future.
Old Feb 17, 2010 | 09:10 PM
BikerV's Avatar
BikerV
I did everything that could be done (I think) to the stock CV carb on my Roadking. Thunderslide, Thunder jet, had it sent out and the whole inside venturi area polished, the stock slide was re worked and the squared off edges rounded for better airflow (after scrapping the Thunderslide), re-jetted...etc. I finally did what I should have done in the first place and bought the HSR 42 Mikuni, IMHO the Mikuni is 10 times the carb that the CV is. Immediate horsepower increase after bolting it on, jetted perfect right from the box for me. No stumbles or flat spots. They have a phrase for dumping money into a stock CV carb, It's called "throwing good money after bad".
Old Feb 17, 2010 | 09:55 PM
krusr's Avatar
krusr
Mikuni HSR 42, You'll be happy,
Krusr
Old Feb 17, 2010 | 10:06 PM
Failz's Avatar
Failz
Originally Posted by rizzo
Failz, FWIW I have the Wood modified CV and it kicks ***. My built 80" on a bagger will pull the wheel up in 2nd. The high flow kit is great, when cruising I get mid 40's mpg and it ill still snort when I get on it. I love the setup.
I really can't justify the $600 he wants though.
Old Feb 17, 2010 | 10:07 PM
Failz's Avatar
Failz
Mikuni huh? Alright then. What all will I need to change to put one on?
Old Feb 17, 2010 | 10:16 PM
BikerV's Avatar
BikerV
Nope, it uses the same manifold. When I bought the Mikuni I got the HSR42 EZ kit (they called it) uses the stock cables. Maybe they all use the stock cables now, I bought mine years ago.
Old Feb 17, 2010 | 10:42 PM
krusr's Avatar
krusr
Mine's a 2000 and I had to use the stock enrichener cable but they're not very hard to hang. I had to do a little fine tuning to find the "sweet spot" but great throttle response and easy to maintain.
Krusr
Old Feb 18, 2010 | 11:57 AM
Failz's Avatar
Failz
Thanks everyone. I'll let ya'll know when I put my Mikuni on and see if it's all you say it is.
Old Feb 18, 2010 | 01:05 PM
hoethree's Avatar
hoethree
HSR 42 Mikuni! best mod I ever made and best money spent on my FXR2
Old Feb 18, 2010 | 02:45 PM
Failz's Avatar
Failz
One more question. I need to get a new A/C don't I? Keihin and Mikuni don't have the same mounting pattern do they?
