Bare bars
Old Feb 28, 2010 | 12:49 PM
Smokey Burnouts's Avatar
Smokey Burnouts
Default Bare bars
Wanting to know what some of yall might have done to get all the "extra"(switches) off ur handlebars.
I want to mount starter switch, lights etc... somewhere other than the bars.
So any pics or wild desgines would be great!
thanks
Old Feb 28, 2010 | 03:16 PM
Smokey Burnouts
no ideas or pics?? haha
Old Feb 28, 2010 | 04:37 PM
guitarman777's Avatar
guitarman777
I think the point is for those switches to be easily accessible. I do like the more minimalist designs for switch housings. I'd be interested in seeing some other ideas like you're talking about.
Old Feb 28, 2010 | 04:55 PM
CamFX's Avatar
CamFX
On my Chopper, I have no switches on the handlebars. Headlight, turn and kill switches alll mounted in my extended dash panel. between the seat and the ignition switch
Old Feb 28, 2010 | 05:07 PM
NSCoyote's Avatar
NSCoyote
from right to left,
Right
throttle, horn, front brake lever.
Center
Speedo
Left
Grip,headlight high/low beam, clutch lever
Old Mar 1, 2010 | 11:11 AM
Smokey Burnouts
Originally Posted by NSCoyote
from right to left,
Right
Center
Speedo
Left
I like!! now is the light switch just a 2 position push button switch? seperate start button or just a on/off/start turn key?
Old Mar 1, 2010 | 11:15 AM
kingofsand21's Avatar
kingofsand21
from right to left,
Right
Center
Speedo
Left
where is your turn signal switch?
Old Mar 1, 2010 | 12:05 PM
Blue SOG's Avatar
Blue SOG
turn signals? why, your HAND... of course!
Old Mar 1, 2010 | 02:41 PM
NSCoyote's Avatar
NSCoyote
the headlight on/off is in the headlight housing, the switch on the left bar is just a 2 postion switc hfor switching between high/ low,
my on/off is in the key which is located just forward of my battery in this pic you can sorta see my keychain hangin near the primary
its my on/off.
what turns signals?
bingo LOL
Old Mar 1, 2010 | 02:51 PM
Shovelhead Jack's Avatar
Shovelhead Jack
My starter is on the right hand side of the tranny, my turn signals are connected to my torso via the shoulder, my headlight has one gear, the clutch is down by my left peg, my horn is either my throttle hand or my mouth, the front brake is on a shelf somewhere and the ignition switch is attached to the magneto in the form of a grounding tab.
Makes for a pretty clean set of bars. All I'd have to do is put an internal throttle on it and the bars wouldn't have **** but grips on 'em.
