Compression
Old Mar 1, 2010 | 10:36 PM
SC-Longhair's Avatar
SC-Longhair
Default Compression
Is there a compression gauge that will tell you your engine is "x:1" or is it derived through using math?
I know there are compression gauges that tell you how much pressure there is in each cylinder.
Old Mar 1, 2010 | 11:21 PM
dope_man_21's Avatar
dope_man_21
Not that I am aware of, but I have been wrong once before. I checked and found a couple of sites that give you some help on the formulas to figure this.
http://www.csgnetwork.com/compcalc.html
http://www.rbracing-rsr.com/compstaticcalc.html
http://www.kb-silvolite.com/calc.php?action=comp
http://www.gtsparkplugs.com/CompRatioCalc.html
As far as turning your xxx lpounds of pressure into compression ratio, I dunno
Old Mar 1, 2010 | 11:43 PM
Bushrider's Avatar
Bushrider
I'm willing to bet that the only way to determine ratio is through the math: Displaced volume/combustion chamber volume. The gauge just tells you how well your rings are sealing and holding the pressure that results from the compression stroke.
However, I too have been wrong.
Old Mar 2, 2010 | 12:54 AM
mplecha's Avatar
mplecha
Calculation is the only way I know of. The compression guages you're talking about really just measure the pressure in the cylinder. Are you getting the cams and headwork done?
Old Mar 2, 2010 | 03:16 AM
CroK's Avatar
CroK
Ditto, compression ratio is just that... A ratio between the open cylinder volume, and the volume remaining in the combustion chamber after the piston is at full top dead center. Ratios are mathematical equations. No gauge can give you that ratio.
Old Mar 2, 2010 | 06:51 AM
32vld's Avatar
32vld
Why the need to know compression ration?
The math is easy to do. Get the formulas off the net. The hard part is measuring the volume of the combustion chamber due to the irregular shape of the combustion chamber area of the head. Bore and stroke is provided by the manufacturer.
Also volume is effected by if the piston is flat or not. Some pistons have raised portions, some pistons have recessed area's for valve clearance. Those area's are difficult to measure for the average person to do. One could do volume displacement tests on the combustion chamber and non flat cylinder heads to get the numbers to do the math.
But one would have to tear down their engine, or get duplicate parts to avoid an engine tear down to take the measurments.
I would think that if one was buying a high performance head or pistion they should be able to provide the volume measurements so the owner/builders could determine the new compression ratio of the new build.
Old Mar 2, 2010 | 06:56 AM
SC-Longhair
The cams will be done soon. I just need to grab some parts. As for the heads, technically I have the money but being unemployed I shouldn't really spend $650 on that. The one thing I'm going to do is Rivera adjustables. They have more tpi than other pushrods and are actually cheaper than the SE equivalent.
@all:
I did search pretty thoroughly before asking. I found quite a few sites that have a form set up and all you do is enter pertinent values.
That's where having the heads cc'd comes in, right? Gives you one piece of the equation.
I appreciate your responses. Thanks.
Fat11Lo
Engine Mechanical Topics
16
Dec 1, 2017 08:25 PM
buellxb422
Ironhead
Jul 25, 2016 08:49 AM
07bobber
Exhaust System Topics
Jan 17, 2014 01:12 PM
JimA
May 4, 2013 02:39 PM
Reffixer
Oct 26, 2005 07:03 PM
