Is dealer taking me to cleaners?
Old Mar 14, 2010 | 05:29 PM
bagga's Avatar
bagga
you don't have to disassemble the whole trans to change a main gear (5th gear) seal. you do have to pull the inner primary tho.
Old Mar 14, 2010 | 07:37 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Take the bike out for a good ride, park on a level surface, check the trans fluid level. If it's been serviced lately it's probably over serviced, it's possible it's just venting and some fluid needs to be removed. If thats the case you just saved at least $490.00. This is the easiest troubleshooting in the book. Also look around the case with a good fashlight and small mirror, underneath looking up, if it's a shift shaft seal you should be able to see this. Good luck with this.
Old Mar 14, 2010 | 08:18 PM
hatchetman's Avatar
hatchetman
If it isnt pouring out I would deal with the little oil spot until next winter. Than you have all summer to look around for a good mechanic that does not work for a dealership. I doubt it will get any worse & as long as you check fluid levels periodically, no damage will occour.
I would not hand over $500 to those goons for a lil drip, most of that is labor, $10 is the seal!
Hatch.
Old Mar 15, 2010 | 12:21 AM
clicker01's Avatar
clicker01
I going with hatchetman on this. You need to find a good indy you can trust - you can never trust the dealer, but that's just my opinion after two sour experiences. If your primary was over serviced, or even if the derby cover wasn't cleaned up real well, you might think you have a leak when you really just have some residual oil bleeding down. Keep an eye on your levels and you'll be fine till you find the cause for sure and someone you can trust to make the repairs. $100 to $200 max.
Old Mar 15, 2010 | 08:44 AM
YZ Guy's Avatar
YZ Guy
Originally Posted by BLKBAGGER
Sound like the shift shaft seal to me. Very common for those to leak. I think you should seek a second opinion.
+1 - that was my first thought.
Old Mar 15, 2010 | 09:17 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by Beancount1
Brought the RK in for service because of an oil leak. When the bike was parked after a ride it left about a silver dollar size stain of oil under the primary. Service manager touch under the primary and said oil was coming from it. Just assumed it was the cover gasket. After the techs look at it, he tells me it's has something to do with 5th gear and he needs to disable the entire transmission and replace gaskets on the inside. Cost = $490. I'm at his mercy because I'm not knowledgeable of the mechanics. Does this diagnosis and cost seem reasonable. Greatly appreciate any advice.
First: Get some simple green and warm water and clean the underside of the bike completely. You can use some brakekleen to spray the bottom completely but go over it with simple green & warm water rinse to remove all residue. Then ride the bike for 20 minutes, shut down and check the trans oil and under the primary for more oil leaking. Try to locate the exact leak. If it is leaking at the front pulley where the drive belt is connected(look under bike) then the dealer is right. If the trans is not low on oil...check the rubber vent tube that comes out of the top of the trans. The end of the tube should be dry. If it is wet with oil then maybe the trans was overfilled. If oil is leaking from in front of where the front drive belt pulley is then my guess would be shifter shaft seal.
Old Mar 15, 2010 | 09:22 AM
KBFXDLI's Avatar
KBFXDLI
Hatch.
Yeah but if it is the main gear seal you have all the case gaskets and seal fasteners on the IP case. Plus you might as well replace all the seals, check any bushings, check the clutch plates while you have it apart. That is what I would do.........yeah find a good indy shop. I am thinking 3-4 hours tops for a good wrench who knows his trade.
Old Mar 15, 2010 | 09:50 AM
faber's Avatar
faber
I guess it depends on the kind of relationship you have with your dealer.
I trust the guys at Yellowstone HD, for a thousand reasons. They have always taken good care of my bike and my wife's.
But if you don't, find an indy and do like KBFXDLI said. While he's in there, might as well get it all taken care of. A motor sgt we had in one of my units used to say, 'If the corrective maintenance you need to do presents an opportunity to do preventive maintenance, always take it.'
Old Mar 15, 2010 | 09:57 AM
KBFXDLI's Avatar
KBFXDLI
Absolutely, the pain in the azz is taking it apart. SO when I go in for a repair I put it all back with all new seals. Especially those sealing bolts on the IP case that some guys use over. Some are made to stretch and seal one time but who wants to take the chance that they will seal twice (many will) and have to do it all over again? I will also do upgrades on corrective maintenance. If my primary has to come apart for anything then I'll get a new welded stator & SE compensator kit and polish my primary chain and get the new regina auto adjuster. Just easier and a lot less expensive.
Old Mar 15, 2010 | 10:20 AM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
Times are hard at the Stealers,so they'll do what ever they can to empty your pockets !!!
