clunk from primary on hard breaking
Old Mar 21, 2010 | 02:19 PM
witter's Avatar
witter
Default clunk from primary on hard breaking
hello people i tried this thread on the trans/primary spot but got only one reply so here goes. when i brake (like while slowing down at a stop sign) i get a clunk or a downshifting type noise from the bike. i read some older threads where some of the guys (mooncricket) was getting the same problem. any ideas? help would be much appreciate. oh and thanks to boomerbob
Old Mar 21, 2010 | 03:24 PM
kingofsand21's Avatar
kingofsand21
Are you sure its coming from the primary? If it is I guess I would start by trying some good synthetic oil you can use in the primary. Does this happen when your holding the clutch in or when your engine breaking too?
Old Mar 21, 2010 | 03:35 PM
Faast Ed's Avatar
Faast Ed
Please describe the symptoms a little more.
It appears that the noise is not induced while down shifting, but comes on it's own as you are slowing? Is this what you are saying? Or is your down shift louder than you expect to hear.
Old Mar 21, 2010 | 04:21 PM
geargrinder's Avatar
geargrinder
Possibly slop in the primary drive chain, I would check the condition and adjustment of the chain tensioner.
Old Mar 21, 2010 | 04:29 PM
BoomerBob's Avatar
BoomerBob
How many miles on the bike, what year and model? Could simply be the primary chain as mentioned. Does yours have an access door to get to the chain adjuster?
Old Mar 21, 2010 | 06:53 PM
witter's Avatar
witter
hi fellows. many thanks for your input,sorry for the lame explanation. the bike is a carbed 06 flst that has the inspection plate. i just adjusted the primary chain after first hearing this clunk. the bike has 15k on it. whenever i hit the breaks hard (and possibly over bumps) i hear this clunk.its the same sound as a downshift but seems to come from primary side.loose motor mounts,bad comp sprocket or?
Old Mar 21, 2010 | 06:58 PM
SeeNoSun's Avatar
SeeNoSun
I have this same problem on my 07 Street Bob. Seems to occur when braking over bumps. It never happened until I had my rear tire changed. The service was performed by an Indy. He has a great reputation and I've never had any other problem with his work.
BoomerBob's Avatar
BoomerBob
It might be your neck bearings need a little adjusting. Sometimes sounds come from one place but we hear it in another.
Old Mar 21, 2010 | 07:05 PM
Albreave's Avatar
Albreave
You said you hear the noise when you go over bumps as well? Did you check to see if it's the suspension? The swing arm gets awful damn messy down there on softails, you know right near the ground...near the dirt. Not saying this is it, I had a mystery noise on my Fatty and it turned out to be the swing arm being dirty.
Old Mar 21, 2010 | 07:34 PM
witter's Avatar
witter
so seenosun did you ever find out what was causing the clunk after the tire change?
