Fork Oil Change Tutorial???
Old Aug 11, 2006 | 12:03 PM
kiltiemon's Avatar
kiltiemon
Default Fork Oil Change Tutorial???
I've done some searches and printed some info off the web, but would still like to know more... Can anyone here please suggest a Fork Oil Change (Fill) Tutorial for a Beginner? I'm adequate with a wrench but I want to know what I'm gettin in to!
Jim aka kiltiemon (Thanks in Advance)
Old Aug 11, 2006 | 01:15 PM
pro1955's Avatar
pro1955
Default RE: Fork Oil Change Tutorial???
If you need to be told how to change fork oil I would suggest buying an HD repair manual for your bike, its a great investment for a DIY guy.
Old Aug 11, 2006 | 01:35 PM
kiltiemon's Avatar
kiltiemon
Thanks, Pro... I have the factory manual and Clymers (or maybe it's Chiltons). I always try to gather as much info as possible before probing into the "unknown". Sometimes you can find a little hint here and there that will make life so much easier!
Jim aka kiltiemon
Old Aug 11, 2006 | 02:10 PM
glstrcowboy's Avatar
glstrcowboy
I just went through this on my Dyna. The book isn't very specific, so here's what I ended up doing.
1. Remove bars and place on tank (with a towel underneath of course!)
2. Remove fork caps with 1 3/8 socket on 3/4 drive palm ratchet. Be sure to hold onto that cap, the fork springs will launch them.
3. Remove drain plugs from bottom of forks and let drain.
4. Remove fork springs.
5. Use a sharpie to put index marks on forks and caps so that the threads line up properly.
6. Replace springs and plugs; pour in new fluid.
7. Using brute strength, compress fork spring with fork cap in socket on ratchet. With indeex marks aligned, reinstall fork caps.
8. Reinstall bars.
Hope that helps. Pulling the bars made life a lot easier for me, and I had a buddy hold the forks while I loosened and tightened the caps.
Old Aug 11, 2006 | 02:11 PM
ReeseSS's Avatar
ReeseSS
Pretty straight forward, jack up front of back, drain oil through drain plugs, remove fork caps and replace oil. Two tools that will help, one that makes it easy to get caps back on by lowering tubes between trees, compresses cap down so you can thread back on easy, then raise up tubes. Even easier, Dennis Kirk has a tool that lets you pump the oil in through the drain plugs, don't have to remove tube caps.
Old Aug 11, 2006 | 03:57 PM
kiltiemon's Avatar
kiltiemon
Thanks all!!!
That Dennis Kirk tool looks like anybody syringe! I think I can fab one from an ink cartridge refill kit and a bit of hose with a cone tip!
Fantastic!!! Now, for what may be a dumb question...., If I put the oil in from the bottom, how does the excess air in the shock get released?
Jim aka kiltiemon
keith t
Jun 7, 2012 02:07 PM
jdvorchak
Jan 20, 2009 11:14 PM
HERITAGEBOY
Jul 23, 2007 01:33 PM
ukchop
Mar 7, 2007 05:06 PM
Shift_4lo
Jul 29, 2006 12:23 AM
