Oil change and level question - HELP!!!
Old Aug 14, 2006 | 09:19 AM
Tn.Heritage's Avatar
Tn.Heritage
Default RE: Oil change and level question - HELP!!!
Clammy I hope you also changed out your filter, if you did sorry for the mention but you didn't say, anyway if you didn't do that, there is the reason for the over fill, 3 qts. will do a softail with the filter just right, 3 1/2 qts and a filter is to much.
I noticed that the Amsoil gets pretty dirty looking also, but they say thats not a bad thing in a way, it's cleaning the engine of deposits and poss sluge[sm=goodidea.gif], so maybe were ok.
Old Aug 14, 2006 | 10:50 AM
Jezcruzen's Avatar
Jezcruzen
Clammy - It seems to be a mystery most of us softail riders have experienced. At my first oil change I followed the service manuel and added 3.5 qts. I had to remove some due to my having over filled it. Plus, I didn't stand the bike upright to allow as much old oil as possible to drain from the oil tank.
Now, I add three qts. after replacing the filter.
BTW - Stop by your local supermarket and buy a cheap turkey baster. They work great to remove excess oil from the oil tank (fits into the fill opening perfectly) rather than removing the drain plug. (Guess how I know!)
Old Aug 14, 2006 | 02:13 PM
Clammy's Avatar
Clammy
ORIGINAL: Tn.Heritage
I did indeed change the filter. If the oil gets dirty from cleaning the engine, that's fine by me!
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old Aug 14, 2006 | 02:14 PM
Clammy's Avatar
Clammy
ORIGINAL: Jezcruzen
Hmm... I didn't know about standing the bike upright to drain more oil. No mention of it in the service manual. Thanks for the tip. I'll make sure to do that next time I change the oil.
Cheers!
Old Aug 14, 2006 | 02:30 PM
Cessna172's Avatar
Cessna172
After the first oil change, and siphoning half a quart out of the oil tank, I said "lesson learned". next oil change comes around and guess what - Darwinism prevailed and I stuffed 3.5 quarts into it again. And again, enjoyed the experience of removing excess oil from the oil tank.
What do they say, "it takes a person hearing something six time before it sinks in"!!!!
3 qts, 3 qts, 3 qts, 3 qts, 3 qts, 3 qts!
[sm=icon_cheers.gif]
Old Aug 17, 2006 | 01:52 AM
bum's Avatar
bum
Clammy,
Same thing happened here. I changed the oil at 500 miles, went to add the 3.5 back that the manual said to do, but since it was my first time ever, I took it slow and checked after 2 quarts. To my surprise, I only had to add a 1/2 quart to it. I had no idea about standing the bike upright. I had asked a couple buddies about the difference in what the manual said to put in and what I had actually put in. The first question was "was the bike upright?" I just did the 1000 mile change tonight and drained it while upright. I checked it at a gradual pace. She took 3 quarts, I cranked 'er up, then added a 1/2 quart to top 'er off. BTW, do not check the level upright, check it while it's on the side stand (even says it on the dipstick).
Old Aug 17, 2006 | 02:25 AM
Punky Brewster's Avatar
Punky Brewster
ORIGINAL: Reino
As mentioned before the drain plug only drains the oil out of the oil tank. If you are fussy take the oil filter off, disconnect the srarkplug leads and hit the starter button for a few seconds until the oil stops spitting out. Makes a bit of a mess so hold a rag where the filter come out. I've done this a couple of times when I've changed from mineral to synthetic oil so I don't get too much contamination.
They sell oil purging systems for Harleys,,,,,,,,,,,,,,,,,i saw it on HDF.My friend bought the system & it works great.gets all the old oil out of your scoot.When your done you'll have 100% clean oil & your dip-stick will have a correct reading.It's a great & easy system
Old Aug 17, 2006 | 03:55 AM
Reino's Avatar
Reino
ORIGINAL: 87lowrider
ORIGINAL: Reino
Thanks Jim, I'll look into it - should be able to get one down this way. I'm about to change brands again in the next service.
Old Aug 17, 2006 | 10:49 AM
dawg's Avatar
dawg
Scavenger system alleges a total oil change.
Old Aug 17, 2006 | 03:29 PM
RELICS's Avatar
RELICS
ORIGINAL: dawg
A friend has this system,works well
