Hey Dyna Bead users
Old May 7, 2010 | 05:09 PM
HD7585's Avatar
HD7585
Default Hey Dyna Bead users
My wife went to the local indy shop today and picked up some dyna beads for me . The service guy told her they don't work well with air.He said nitrogen is the only way they will work. I'm thinking this ain't so. I assumed most of the good reports I've read here on dyna beads were with air used in tires.............Alll opinions appreated...........Thanks
Old May 7, 2010 | 05:15 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
Go to Dyna Beads website and ask them !!!
Old May 7, 2010 | 05:18 PM
Brooklyn Devil Dog's Avatar
Brooklyn Devil Dog
What a bunch of crap! Now Obama has a bike shop?
I hope you're not going to keep bringing your business to him.
Old May 7, 2010 | 05:21 PM
RoadKingRon1's Avatar
RoadKingRon1
They work with air or nitrogen. The problem comes from moisture. Compressed air carries a lot of moisture whereas nitrogen is more stable.
A little moisture causes the beads to clump together negating their effectiveness. So far no problems here and I'm using regular air.
MilesJ's Avatar
MilesJ
Well I don't run dyna beads but I can garauntee you that he is full of BS!! The concept of dyna beads is that they dynamically balance a tire and rim by finding the opposite moment of an imbalance. Unless your air is thick and dense enough to stop the beads from moving around in the tire there should be no difference. The dyna bead website says Nitrogen is an "ideal" environment for the beads but doesn't say why other than Nitrogen doesn't have same moisture level when purged blah blah blah.
Old May 7, 2010 | 05:24 PM
MilesJ's Avatar
MilesJ
A good example of why I hate to use a gas station compressor to fill my tires. I have seen some horrible amounts of moisture coming out of the hoses. I will only use my compressor or a reliable shops unless it's an emergency.
Old May 7, 2010 | 05:25 PM
RoadKingRon1
.............Just saw your reply.
Old May 7, 2010 | 05:32 PM
Brooklyn Devil Dog
Besides the moisture factor, nitrogen is also considered "ideal" because it doesn't expand/contract with temperature changes as regular air does. Provided you check your tire pressures periodically, however, regular air is just fine for DynaBeads.
Show this thread to your indy and see what he says.
Old May 7, 2010 | 05:36 PM
schumacher's Avatar
schumacher
I've heard arctic air works best with them
Old May 7, 2010 | 05:39 PM
RexBuck's Avatar
RexBuck
I have used Dyna Beads for awhile - both with air and nitrogen. They work fine either way. Incidentally, isn't air 80% nitrogen?
I'd run away very fast from that Indy.
