I work as a Toyota Tech. My boss (owner of the dealership) decided to test out Nitrofill. He had two tires on his personal car filled with Nitrogen and the other two filled with normal compressed air from our shop compressor. Ran that way for six months, checking the pressures every two weeks. No difference found after six months.
The air we breathe is 78% nitrogen, 21% oxygen and 1-2% everything else. As for the pressure change from temperature, think about it. The pressure changes in the average tire (car or motorcycle) is about 20-30 degrees. There are three places where extreme temperature changes can make a real difference in pressure in tires. Aircraft, where extreme altitude changes can equal 50-60 degrees change or more. The space shuttle for the same reason, and NASCAR, where a very slight change in air pressure can have a major impact on the handling of a vehicle.
How many of us are out there doing 197 MPH? Meanwhile places are charging $40 and more to fill your tires with nitrogen. And what about the air that is already in the tire when they fill it with nitrogen? They don't vacuum the air out before filling it. The basic principle of nitrogen in tires is scientifically sound, but realistically unsound.
The reason shops that sell nitrogen push it is that they can then offer free refills and top ups, thereby getting you to return there once a month so they can inspect your vehicle and up sell more maintenance and repairs.
In the latest issue of Motorcycle Consumer News Dyna Bead company took issue to MCN's negative evaluation of their product. DB said something to the effect that MCN's Honda 599 had vibration issues and Dyna Beads won't work under those conditions, the beads wont help an out of round tire, and that over time the beads find the lightest spot. Also that perhaps MCN didnt install them correctly and their evaluation really didnt prove they dont work. And Dyna Beads website has proof the beads work.
MCN responded saying they bought the beads and installed them as instructed and they arent beholding to the manufacturer. That Hondas 599 isnt a real smooth motorcycle, but many other motorcycles arent either. They also said the beads would be moving around to different locations during braking and stopping and stood by their recommendation to not use them and instead get a proper weight balance. They advised Dyna Beads websites anecdotal evidence did not prove they worked at all. Instead they challenged them to provide prove to their statement Dyna Beads can up to double tire life claim.
Tell you what, come on up north where we get wild temperature swings and see if it makes a difference. I have one vehicle that as air and one that has nitrogen from factory. Every time the weather changes in the air one my stupid tire pressure warning is going off, and it doesn't in the one with nitrogen. That alone makes it worth the 40 bucks to me!
...No difference found after six months... The pressure changes in the average tire (car or motorcycle) is about 20-30 degrees...
Like MilesJ says, come up North sometime. During a 6-month period, temperature differentials can easily exceed 100 degrees F. between hot summer highs & cold winter lows.
I wondered about this nitrogen in the tires thing. If your tires are low on pressure do you have to go to a dealer or can you buy cans of this stuff to top off on the fly?
You didn't know???
yeah, okay. not doubting that. but don't you check your tire pressure more often than once every 6 months?
