Noticed a vibration yesterday...
Old May 30, 2010 | 07:54 AM
chuckw2's Avatar
chuckw2
Default Noticed a vibration yesterday...
Went for a nice ride to Yucca Valley and Pioneertown yesterday. The bike ran great but I noticed when I hit a rise big enough to unload the suspension a bit I could feel a vibration in the seat but not the bars. Didn't do it going down the road-smooth as glass then. It's a very definite sensation-like the engine is contacting the frame at that point or something. Any thoughts?
Old May 30, 2010 | 08:00 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Motor mount? Is your seat on as tight as it can be? Twin cam A motor?
Old May 30, 2010 | 09:12 AM
chuckw2's Avatar
chuckw2
I thought maybe a motor mount. Seat is tight. Evo motor. I was thinking since the swingarm pivots off the rear of the trans maybe some contact there when the rear suspension is extended.
Old May 30, 2010 | 09:20 AM
Arv's Avatar
Arv
Sit and take your time, look for witness/chaffing marks, you will see something if its making contact.
Try also jacking your bike up, to release the pressure of the rear suspention/swing arm, making sure its strapped down, turn rear wheel maybe even start it then run on tick over in gear (be carefull)
Old May 30, 2010 | 09:34 AM
Jonesee's Avatar
Jonesee
Evo's come in both A and B configurations. But I assume you are discussing the bike in your sig pic. It is a Dyna and an "A" motor.
How many miles have you personally put on the bike? All Dynas vibrate under different circumstances. It is in their personality. If the bike is new to you, don't drive yourself nuts yet.
The first thing I would do is take a heavy screwdriver and tap the bit of the screwdriver on the head of the bolt of every motor mount. If one has loosened much you will notice it by the sound.
If the bike is new to you or how many miles are on it. It might be worth setting it on the jack and starting at the front, woirk your way back checking every fastener. Take a hard look at the suspension if the miles are gettting up there on it.
Remember though, if it is new to you and you just noticed it. Dynas vibrate. Some in strange ways under different conditons and speeds.
Old May 30, 2010 | 11:11 AM
chuckw2's Avatar
chuckw2
Thanks. It is the bike in my pic. Didn't know about the A and B configuration on Evo's. What is the difference?
The odo shows 70k, the seller claimed the engine was rebuilt 7k ago. It runs great, doesn't leak or make any weird sounds. I've only had it a month and yesterday was the first ride of any real distance. It gave me a chance to really get the feel of it and that was the only thing I noticed that seemed out of what I would consider normal.
I will do the screwdriver/bolt check.
My last Harley ride was 30 years ago on my rigid pan so it's been a while but I know about Harleys vibrating-that's part of the charm!
Old May 30, 2010 | 11:22 AM
Sgt. Fury's Avatar
Sgt. Fury
"It's normal, wait that's and evo, we don't work on those." If it's when the rear suspension is unloaded, it could be the swingare/trans mount getting a little sloppy. They don't last forever.
Old May 30, 2010 | 02:28 PM
Jonesee's Avatar
Jonesee
Your bike has an unbalanced, rubber mounted motor by design.
At 70,000 miles the suspension has had a fair amount of miles. I would put it on the jack and give it a good once over. By now everything has loosened up and some things may be getting sloppy.
Old Jun 17, 2010 | 11:44 PM
buckfxstc's Avatar
buckfxstc
5th Gear
Default 1997 fxstc new vibration
I have a 1997 fxstc, 22k, put new METZLERS on ~ 6k ago. In last 2 weeks noticed vibration in grips, hands going numb...slight vibration on pegs...motor mount appears fine...any ideas?
thanks...
Old Jun 18, 2010 | 01:41 AM
Other Sheep's Avatar
Other Sheep
You guys are riding an EVO. They vibrate. There is no A and B motor. There is just an EVO. The Dynas and Touring models are rubber mounted. The Softails are rigid or hard mounted. You're going to feel vibrations through the bike especially on the rigid mounted Softails. The vibes change depending on suspension load and unload and RPMs. That's why Kuryakyn came out with the ISO stuff. It was made to isolate the vibes from the rider. Enjoy your ride.
