Do I really need to have my clutch adjusted....
I am just now adjusting my clutch at the clutch pack for the first time. I am using a 7/32 T-handel hex for the adjuster screw and an 11/16 open end wrench for the jam nut but it an't budge'n. It is real tight and the wrench keeps slipping off do the the angle. Is an offset wrench advisable for this use? I am getting concerned that I am going to strip something so I am taking a break. Advise would be appreciated.
Tim
Well, as it turns out, I'm in the middle of the 15K service and I can't seem to get the right setting on the "back out" setting. I like my clutch to release 1/8" from full squeeze. I mean as soon as I let off finger pressure, I want her to start grabbing.
For the first run, I backed off 1/2 turn. I could barely ride the thing because it took so much real estate (handle away from bar) to engage. I used the cable adjuster to fix that, but the clutch handle has an inch of slack.
When I read this, I thought, Whoopee, and I hurried out to re-adjust with 3/4 turn of backoff. Well, I've still got an inch of slack in the clutch cable.
Is this clutch wear that is not gonna go away until I spend (???? hundred $$$) with the dealer for a new clutch? If I do this again, and back off a whole turn, will my slack go away?
BTW, after fifteen hours of reading this forum, 33 hours of getting my stuff together, two weeks of worry and planning, I completed the 3 hole service today. What I did wrong, even after all the planning? Put the filter on without putting any oil in it, and put the derby on with no oil in the primary. Yeah, I caught it in plenty of time, but it was frustrating. And as a teenager I spent two years under cars in the local service station changing oil and greasing cars and changing tires. Not my first rodeo, but it was my first time of this particular bull.
So, whassa answer to my clutch dilemma? And if you've never ridden with a clutch that engages at the slightest touch, you don't know what you're missing. Thanks for all y'alls help. I'm gonna go "test ride" in some 100° North Carolina heat. Boots and jeans, yeah, but the leather is staying in the closet.
And by the way, I want to thank Harris for the motor office training course he sent me three years ago. I spent hours and hours in the parking lot stopping and starting at that 2X4 and practicing the exercises, and man, does it pay off. I'm not about to scrape floorboards just to show off, but knowing I can handle this big bike in a tight parking lot does wonders for your confidence. Every time I go to the grocery store I do tight turns just to stay on top. Thanks, my good friend.
It's very unlikely that the clutch pack itself is damaged or significantly worn. Despite what you read on line the stock H-D clutch is damn tough.
Harris
