Amsoil filters
Old Jun 25, 2010 | 06:53 PM
jlandis874's Avatar
jlandis874
Default Amsoil filters
Anybody use them? I use Amsoil but have always used HD filters but from what I hear Amsoil filters are supposedly the best out there. Anyone?
Old Jun 25, 2010 | 06:58 PM
DanD's Avatar
DanD
I use em.they're better. but then,I like amsoil enough to get a dealership,and I use amsoil EA filters on everything.
Absolute Efficiency
AMSOIL Ea Oil Filters (EaO) have the best efficiency rating in the automotive/light-truck market. EaO Filters provide a filtering efficiency in accordance with industry standard ISO 4548-12 of 98.7 percent at 15 microns, while competitive filters containing conventional cellulose media range from 40 to 80 percent efficiency.
Less Restriction
AMSOIL Ea Oil Filters have significantly lower restriction than conventional cellulose media filters. Their small synthetic nanofibers trap smaller particles and hold more contaminants, resulting in lower restriction. During cold temperature warm-up periods, an EaO lube filter allows the oil to easily flow through the filter compared to a typical cellulose filter. Lower restriction decreases engine wear.
More Capacity
A filter’s capacity refers to the amount of contaminants it can hold and still remain effective. AMSOIL EaO Filters have a greater capacity for small, wear-causing contaminants than competing filter lines do. In most applications, when used in conjunction with AMSOIL synthetic motor oils in normal service, EaO Filters are guaranteed to remain effective for up to 25,000 miles or one year, whichever comes first.
Superior Construction
AMSOIL Ea Oil Filters are made with premium-grade full synthetic media. The strictly controlled processing of this media ensures accurate filter construction, and is what allows Ea Oil Filters to deliver higher capacity and efficiency along with better durability.
Over the service life of a conventional cellulose filter, hot oil will degrade the resins that bind the media. The Ea Oil Filters’ full synthetic media technology is resin-free. It uses a wire screen backing that is pleated with the media for superior strength.
Ea Oil Filters are constructed with HNBR gaskets that are fully tested to extreme distances in numerous severe environments. The filters also feature fully tucked seams, a molded element seal, roll-formed threads and a long-lasting premium-grade silicone anti-drain valve.
Applications
AMSOIL Ea Oil Filters provide superior oil filtration for vehicles in the auto/light truck market.
Service Life
AMSOIL Ea Oil Filters are guaranteed for 25,000 miles or one year, whichever comes first, when used in conjunction with AMSOIL Synthetic Motor Oil. AMSOIL recommends changing the oil filter at the time of oil change.
good enough foir me,especially considering the moco oil and filter is made by the lowest bider that meets the minimum specs.
Old Jun 25, 2010 | 07:06 PM
DanD's Avatar
DanD
slorider101
Oil Archive (no new posts)
May 19, 2015 03:49 PM
user 6974208923
Jun 21, 2012 07:45 PM
CRBandit
Aug 22, 2011 03:18 PM
BackinBlackfxdb
Aug 4, 2010 08:16 PM
Lord Albany
May 9, 2008 07:49 AM
