When to change tires
Old Jul 1, 2010 | 06:49 PM
Jim Kraft's Avatar
Jim Kraft
Default When to change tires
How far down do you guys wear your tires before you put on new ones? It seems like mine get down to about a 1/16" tread in the middle, and then go for a long time after that, before the center tread is all but gone. Most of my riding is around 55 and below, and some up to 65, but not much. This is on a 99 FXSTC.
Old Jul 1, 2010 | 06:56 PM
petemac's Avatar
petemac
I don't have it in front of me, but I think the manual say's to replace them at 3/32 which is when the wear bars are supposed to show.
Old Jul 1, 2010 | 07:03 PM
dope_man_21's Avatar
dope_man_21
That would be correct.
The Op had 1/16" or 2/32" so to ther OP, you should of already replaced them by now, those are the only thing keeping you off of the asphalt.
Old Jul 1, 2010 | 07:15 PM
dynhd1's Avatar
dynhd1
Right before it looks like they need replacing!
Old Jul 1, 2010 | 07:17 PM
badwhine's Avatar
badwhine
3/32 and I replace.
Old Jul 1, 2010 | 07:21 PM
Jim Kraft's Avatar
Jim Kraft
OK, I was going by the 99 Softail manual, that states tire wear down to the wear bars at 1/32". I do change mine before the air shows through. LOL
Old Jul 1, 2010 | 07:24 PM
cruise_carter's Avatar
cruise_carter
tires have date codes on the sidewall, good idea if you are not putting a lot of miles on during the year to replace them when they get some years on them.
something else to consider besides tread depth......
Old Jul 1, 2010 | 07:45 PM
skootchnc's Avatar
skootchnc
buddy of mine rides the tires, until there's nothing left to hold air...
I replace them when the wear bars show (3/32)....
There are two things I won't try to save money on...... tires and brakes
but that's just me
Old Jul 1, 2010 | 07:46 PM
Jim Kraft's Avatar
Jim Kraft
I agree on years also. Mine are mostly worn out at 1 or 2 years, except for the front which sometimes goes 3. That skinny 21" front seems to go forever. I do ride about 7 to 10 thousand miles a year. It's just that the last 1/32" to get to the wear bars runs a couple thousand miles more. Maybe I will start changing them sooner than what the book says, just for a little safety margin. That seems to be what you guys are doing.
Old Jul 1, 2010 | 07:50 PM
Jim Kraft's Avatar
Jim Kraft
Maybe my service manual is wrong, but it says the wear bars are at 1/32". That is what mine are on Dunlops anyway. Car tires are 3/32" to the wear bars.
