screaming eagle "high compression" plugs.
Old Jul 14, 2010 | 07:28 PM
ajnccn's Avatar
ajnccn
2nd Gear
Default screaming eagle "high compression" plugs.
I just got a new set of plugs for my 05 1200r from the dealer. I asked for screaming eagle plugs and the salesman asked if I wanted the high compression ones. I said sure, whats the difference. I installed em, bike runs fine and sounds fine. I pulled one after 20 miles to check the condition becuase the box said for race applications that run a richer mix to see what they looked like. They looked like the bike is running a bit lean. Is this normal for these plugs? The bike was fine with the regular plugs. Should I just switch back or fiddle with my mixture screw?
Old Jul 14, 2010 | 07:40 PM
Mntsnow's Avatar
Mntsnow
I'm going to go out on a limb and say that the high compression plug is running hotter than a standard style plug due to it's different insulator design. I have been told that with the high compression plugs you need to run 1 to 2 steps colder plug compared to a standard plug.
Old Jul 14, 2010 | 09:01 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the thought about those plugs being one or two steps colder. Pull them again in a couple hundred miles. Typically a colder plug doesn't maintain the heat to "burn" off deposits, probably didn't say that right.
Old Jul 14, 2010 | 09:26 PM
bwana1's Avatar
bwana1
SCREAMIN EAGLE, TASTES LIKE CHICKEN!
$5 for a gd spark plug for a stock 1200.
Champion RA8HC, identical to the HD OEM plug, for $1.25. Work great and last a long time.
Bwana
Old Jul 15, 2010 | 08:18 AM
XL50#674's Avatar
XL50#674
I have the SE 10mm plug wires since they look cooler and were only $20.00, but I always use the stock HD plugs. I use OEM plug in everything unless the engine is built like crazy. You should be fine with thoes plugs.
ironfist_001
2014-2024 Touring Models
24
Aug 19, 2018 04:06 AM
DieselDoc103
Engine Mechanical Topics
Apr 8, 2017 09:46 PM
Bluesrider.df
18
Apr 4, 2016 02:35 PM
sonnybonus
Nov 30, 2009 11:01 AM
Jessie
May 10, 2008 12:02 PM
