I'm right in the middle of changing my lowers to chrome and I stripped the 6mm bolt, which holds the uppers to the lowers. I haven't a clue what to do. Harley Stealership told me I would have to purchase an entire new fork. Any help would be appreciated.
I just noticed your other post said it's the head of the bolt. Drill it and use an easy out. Or take it to a machine shop and have them do it if you can't do it yourself.
That video seems like a good alternative.
I had the same issue you had when i did a fork lower swap.
I ended-up having to drill the head of the bolt, slipped leg off and then removed bolt with pliers...would have been nice to try the hammer trick.
