valve stem cap
Old Aug 3, 2010 | 11:58 AM
  #31
alaskajeff's Avatar
alaskajeff
Originally Posted by carpetride
That's exactly why you should only use genuine Harley Davidson parts.
Could have caused serious injury or death.
You bet, I'm one of the lucky ones....
Old Aug 3, 2010 | 01:46 PM
  #32
brenn's Avatar
brenn
OK, seriously, here's a warning about something I just learned about HD valve caps.
I was trying to put air in my rear tire and nothing would go in or come out. People here suggested a bad valve, so I was going by the dealer anyhow to start a group ride and they put in a new one, no charge (not much, but nice since it's an old bike I bought elsewhere).
BUT, when we took it out a little O-ring fell out and it turns out the fancy HD valve stems have little O-rings that will fit right inside the valve stem and jam it up. Anyhow, I took the O-rings out of the other caps and they're fine. So if you get some of those $29.95 HD chrome valve stem caps (or $5 or whatever), you might want to stick a nail in and pull out the O-rings before you use them.
Old Aug 3, 2010 | 01:54 PM
  #33
RHPAW's Avatar
RHPAW
Let's see, should I multiply X12 if I only have a Lb. torque wrench?
This is really getting complicated.
12-15 Lbs torque if using air.
14-18 Lbs torque if using nitrogen.
I put Propane in my back tire, so I got mine torqued at 23-23 (Man....you should see it when I do a burnout).
And I put Helium in the front tire. Makes it easier to do a wheelie.
Old Aug 3, 2010 | 02:14 PM
  #34
DPete's Avatar
DPete
Propane won't do it, I put Amsoil in mine and when it blew the valve cap off cause of improper torque it came out like black water, damndest thing I've ever seen, lost all viscosity, changing back to Dino air and going to red locktite.
Old Aug 3, 2010 | 02:26 PM
  #35
rh8234's Avatar
rh8234
I can't believe how many people took that question seriously! WTF. Anyway, do what I do. Put the cap on with some JB WELD, and you'll never need to worry about it again.
Regarding those little o-rings is some of the caps HD sells - toss 'em in the trash! the schrader valve should prevent leaks from the stem. The o-rings only cause problems. No need for them.
Old Aug 3, 2010 | 02:42 PM
  #36
Tony P's Avatar
Tony P
Hilarious thread! It's a real poke at those who torque everything down to their quick release seat.
Old Aug 3, 2010 | 04:14 PM
  #37
barjbar's Avatar
barjbar
If the valve cap is stuck I find an M80 removes it easily. Just make sure your bike insurance is up to date and you want a new bike.
Old Aug 3, 2010 | 07:32 PM
  #38
ROMPUS's Avatar
ROMPUS
just use common sense
Old Aug 3, 2010 | 07:46 PM
  #39
Wingnut51's Avatar
Wingnut51
Now what kind of smart-aleck response is that? The poor guy asks a legitimate question about the precise torque values for his valve stem cap and you want him to use common sense? What the heck does common sense have to do with owning and maintaining a Harley?
Old Aug 3, 2010 | 07:47 PM
  #40
gonzo956's Avatar
gonzo956
same torque spec as the ones on your car....
