Trailer Advice PLEASE
Old Aug 9, 2010 | 06:53 PM
firefighter156's Avatar
firefighter156
Originally Posted by monstead
I went through the same thing last year. Ended up with an 8x12 true V.
IMO, 12' is plenty. The box is 12' PLUS the V-nose part, which is not in the calculation, gives ample room for "stuff". Even though I have an 8' wide trailer, the wheel wells take up some room and get in the way a bit, so I'm not so sure I gained as much as I thought I would. It is nice as far as having a little more elbow room when loading/unloading and moving around the bikes.
We have carried my RKC and a RG...somewhat staggered, with room for all sorts of gear. I now pull with a pickup and last trip, I had my dogs in the backseat, so all our gear went in the trailer with room to spare. Unless you just want a ton of extra room, the 7x12 should be enough. I was like you, but it was between a 7x14 or the 8x12.
Here's a couple pics for ya. The RKC is set so it's about 1' more towards the back than the bike/chock on the left side. We wanted to keep the door area open, plus, keep the handlebars/fairings off each other. Pics don't do a very good job in showing how much room is in the trailer, but maybe they'll help.
What wheel chocks did you get?? Is there a brand name of trailer you found to be better than the other??
Old Aug 9, 2010 | 07:16 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Localprez
I am in the process of deciding on a new motorcycle hauler. Here are the items I have my mind made up on.
1) 7 ft wide
2) Tandem Axle
3) 5 ft inside height
4) V-Nose
What ever you do DO NOT buy a trailer with a 5 ft inside height...you will regret it
Old Aug 9, 2010 | 07:19 PM
Tx_Rider's Avatar
Tx_Rider
I have a "Carry On" brand 7 x 12 dual axle w/elec brakes.
I added E-Tracks, painted the floor with garage floor paint and added a 5k D-ring in the rear center.
On the front wall I added some Gladiator Gear Track to hold different items.
I have it set up with 3 wheel chock base pates to accomodate 1 or 2 full size bikes.
My Wheel chocks are from Harbor freight and work well.
Old Aug 9, 2010 | 08:47 PM
SC-Longhair's Avatar
SC-Longhair
If the extra 2' is worth the money to you, buy as much trailer as you can afford.
Old Aug 10, 2010 | 11:07 AM
monstead's Avatar
monstead
From: Dallas, TX & Santa Fe, NM when I can find the time....
Originally Posted by RoadKingRon1
Nice set up you got there Monstead (you poser lol)
Go with the 14'. The longer the trailer the easier to back.....Can you go taller? Wear your helmet while loading and unloading.
I've got a 8.5 X 20' slope nose. Can haul a car if need be or 4 bikes or a lot of furniture etc.... And my 1/2 ton Yukon pulls it fine.
I suppose you could say I'm a card-carrying member of Posers-R-Us. Wear assless chaps too. Don't do fingerless gloves though - gotta draw the line somewhere!
Old Aug 10, 2010 | 11:25 AM
oldairboater's Avatar
oldairboater
For two bikes you need at least a 7x14 to be comfortable. I have a 6x12x6 and load two bikes in it but I am cramped during tie down. With removable wheel chocks I can stagger two bikes or center one bike when hauling them. I went with a single axle. It was still in my load range. I would suggest doing a search on here. There are a lot of trailer question and some good ideas to consider besides just this thread.
Old Aug 10, 2010 | 11:29 AM
monstead's Avatar
monstead
I ended up with Condor Chocks because I wanted a stand alone chock that I could remove easily (special hardware for that) for use elsewhere...like for oil changes and such. I also wanted some flexibility in being able to move it around the trailer for different scenarios.
Almost got Harbor Freight chocks after reading reviews...much less $$. I did find a seller here in DFW that made me a great deal on the 2 Condors. My only "complaint" with them is I cannot get my bike off them w/o help from a 2nd person. I can usually get the Deluxe off, but never the RK. I'm just not strong enough. Similar quality and easy to back off alternative is forum sponsor "Wheeldock" chock. Worked it at a show and really liked it...esp being able to back the bike off by stepping on a bar.
Just hauled my Deluxe to Santa Fe along with a friends Fatboy. Brother had borrowed one of the Condors so we only had 1 bike in a chock. We just ratcheted the other down real well. This worked just fine...checked the load often just in case. Bike never moved. Don't recommend it, but it can be done. Heck, pingel chocks work fine and are much less $$ if you're staying within a budget. You can always upgrade later. I do recommend investing in quality tiedowns though. Powertye brand is one that comes to mind.
As far as "brands"...I'm guessing it could be a regional thing, but I kept hearing good things about Wells Cargo & Haulmark. Mine is Continental Cargo. The company makes numerous trailers under different names (Parent is Forest River). I did my research and they built in the same quality as the name brand guys. Steel construction, torsion axle, dual axle, brakes, etc. All the things I was looking for. I did a good bit of research and went down to the actual manuf plant to pick it up and got to see several trailers in various stages of construction.
At the end of the day, it's a box on wheels. Get the "best" your budget allows and don't be afraid to buy used. The price goes up with the amenities/name brand. I was dead-set on True-V, torsion axle, dual axle, brakes (all have that it seems), and one I could stand up in. You can fix it up yourself with all the other niceties as you go along.
Wax it and take care of the tires.
Old Aug 10, 2010 | 12:05 PM
RoadKingRon1's Avatar
RoadKingRon1
May I join your club?
With respect to Monstead, my experiences;
I have the Harbor Freight chocks because I'm frugal (cheap?) They take up more room than the Condor but I improvised a quick release. My wife cannot get her Deluxe out of these by herself either.
And this is the gospel......
I bought a United Trailer (made in Indiana) because of the sloped nose. The old V-nose I had didn't pull well in windy conditions and removing the bug guts from the leading edge was a pain. The rear spoiler on my Yukon deflects wind and bugs over this trailer.
I do have a water leak in heavy rain that they can't seem to find. The sides of my trailer are screwless standing seam which looked great but now the seams are trying to separate on one side. So I cannot recommend you purchase a United trailer.
The good - wife an I can put a double air mattress in the front with our bikes loaded and all camping gear including a small "fridge" and head out to the Nationl Forest and campgrounds.
If possible get at least a 6' ceiling height...
Old Aug 10, 2010 | 01:23 PM
Nickrc3's Avatar
Nickrc3
From owning several enclosed trailers over the past 2-1/2 decades my advise for two bikes are:
  • a 7 x 14 - perfect for two bikes
  • torsion suspension
  • 6' inside height - Why consider 5' unless you intend to garage it due to homeowner's association requirements?
  • Select a reputable manufacturer (Wells Cargo, Continental, HaulMark, etc.) who provides customer support and a decent warranty.
My current trailer is a Wells Cargo w/ Sport-Pak, and is by far the best in functionality and quality/fit of components. They may be priced higher than the others, but worth it. Standard features included with the Sport-Pak are a domed front (makes a huge difference with air resistance), air vents, 3/4" plywood floor, 1/2" ply on inside, aluminum diamond-plate skirts and fenders, top-quality exterior hardware, full undercoating, aluminum mag wheels (instead of the generic white wagon-style), built-in rear supporting jacks, color options, etc. Even the weatherproofing caulk is color-matched to the finish.
Good luck.
Old Aug 10, 2010 | 03:50 PM
dfndr's Avatar
dfndr
Had our Wells Cargo with torsion suspension for over two years. MANY miles. One screw holding on the siding rusted. That's the only thing! Tows great, no leaks, no problems at all. Would buy another. Be sure you can stand tall in it.
