A friend of mine got into a discussion on the longevity of our Harleys. He said they are not made to last. He has done just about everything you could do to his 2007 RK. I said if you just leave the bike alone with maybe a stage I the bike would last as long or longer than another bike out there. Harley is not in the business of doing their research and design to have the motors last only 50 70,000 miles. I'm I going crazy, or am I correct.
You're absolutely correct. There will always be problems, and problem bikes off the assembly line but overall the bike is built to last. At Harley's design specifications anyway. Stage I, a tuner and minor things like that won't change anything, but if you start introducing other parts, you're introducing an unknown factor into the equation.
Leave it alone and ride it, that's my new theory. I haven't done engine mods since my 88 FXR.
I have 15,000 miles and a stage one on mine now , I'll let you know how it goes in a few years..
A buddy at work has a softail with 75,000 miles, rebuilt twice, but it's carbed not fuel injected, if that matters.
It shouldn't, but that depends on what you mean by rebuilt. I don't equate a top end rebuild (basically just replacing gaskets and maybe pistons) a complete rebuild.
I believe keeping the bike properly maintained is the key and if done so, should last well past 100k before needing a rebuild. I've got close to 50k on my bike and never had a peep out of it. (Knock on wood....)
You are correct. Stage one and ride and you are fine. I had 45k trouble free miles on my '04 Ultra before it was totaled by a careless cager. I did stage one and vance & hines pipes and nothing else.
If you're not hot-rodding it and you maintain it properly these bikes will run 100k without any serious issues other than routine maintenance. Throw in a rebuild and 200k is not unheard of.
My last bike had 92k on it before it was totalled by a hit n run driver. I was looking forward to seeing it roll over 100k ('05 EGC). I'd had no problems with it at all. It was a stage II and other than it sucked gas more than I liked, it was a great bike and very reliable.
This bike ('09 RK) just turned 35k and is running smooth as silk. I've left this one completely stock and am enjoying it this way. I log alot of miles and will hit the 100k mark with it in about 2 years from now. I'll keep you posted...
100k is a piece of cake. Routine maintenance is everything. I ride with a buddy that rolled-over 160,000 on his 01 Ultra this summer and he has had two sets of tensioner shoes and one belt replacement, but he is box-stock.
I have been running the full Stage II since 45,000 miles ago and other than the usual tensioner issues, etc. I am not concerned about it at all. The 07 has the hydraulic tensioners and and larger pump anyway. If I had an older model, I would go to the Hybrid Hydraulic kit and pretty much end tensioner wear issues. I have already done that.
Like you said....leave it alone and it will last longer. When you start bumping-up compression and valve lifts....you just put more pressure on the wear surfaces. The bike was never intended for walking it down the road on the rear wheel....leave that up to the crotch-rockets.
