Fault Codes P0261, P0263, P1003
Had the same issues. First it only happened every once in a while. The bike would die while riding or wouldn't start. Eventually it would fire right up and be OK. Then it got to the point of not starting at all. I noticed that there was no sound from the fuel pump when turning on the run switch. Found this forum thread and decided to try the cheap route first. Talked with the local Harley service department and got the generic "We can't really tell you anything without checking the bike out, bring it in" I decided to try the $8 relay located on the right side under the side cover. I cleared the codes, installed the new relay, turned on the ignition, and hit the run switch. Fuel pump came on and it fired right up. Glad I found this forum and hope this helps others!
I haven't figured out how to do this site yet but I like it. The 0261 code didnt help but the reply,s are excellent. I the dealer nearest me wouldn't even do the 2 recalls unless I paid full price plus labor. They dont stock any parts and are 35% higher than I can order them. I'm trying in the morning the system relay and connections. 13,000 on an 07 never had a problem until crazy symptoms with fuel and pump and starting and running. Ordered a new pump with reg. And filter. I'll put my reply in the right place next time.
There, now I've taken part in a 10 yo necro thread.
It just occurred to me that "recall" might be typo for "relay" in which case I apologize.
iamthenightrider
Sep 17, 2015 06:58 PM
