P1351 and 1354 codes
Old Apr 22, 2009 | 01:48 PM
yankeeflyer72's Avatar
yankeeflyer72
Default P1351 and 1354 codes
This has also been posted in the Tech and DIY sections
Yesterday while my wife was riding her '08 Deluxe, everything engine related shut-down. I managed to get it going again and we brought it home. I initially thought she had hit the kill switch without knowing it. We took it out again and the same thing happened. Brought it back home. I ran the diagnostic mode on it and got the P1351-Front Ignition Coil Driver Open/Low and P1354- Rear Ignition Coil Driver Open/Low. What is the significance of these codes. I checked for loose connections and everything seems tight The bike has about 14,000 on it and is still under warranty but I would like to have an idea as to what is going on before I decide whether to take it in. I`ve worked on bikes all my life. Started out on a '62 Pan, but these new computer control systems have me buffaloed. Will probably talk to the shop today but would like any input on what might be going on. Thanks in advance.
Old Apr 22, 2009 | 02:08 PM
Toypuller's Avatar
Toypuller
Check for loose or corroded fuses and relays.
If no luck there, idle the bike and shake the wiring harness around and check for broken, worn or grounding wires.
Sounds like an intermitent electrical problem.
Are the codes current or stored?
Old Apr 22, 2009 | 07:49 PM
yankeeflyer72
The codes are current. I check for codes regularly just to keep track of things. I`m sure these occurred yesterday, Tuesday, when the bike shut down.
Old Apr 22, 2009 | 08:45 PM
Toypuller's Avatar
Toypuller
By stored or current I mean are you showing a constant check engine light or does it flash after start and then go out.
If it is constant it means the problem is continuous vs if it is flashing it means it was a on/off type problem.
In any event, I would start at the fuse block and wires.
Old Jun 30, 2009 | 10:38 AM
SixpackUSMC's Avatar
SixpackUSMC
Stage III
Yankee, did you ever figure this one out? I am having the same problem on an 07 SB and it's been reoccurring for a few weeks now.
Old Jun 30, 2009 | 11:32 AM
yankeeflyer72
Yeah I figured it out. The positive lead on the starter had gotten a little loose. This caused a split second arc, power loss, or whatever you want to call it. When it did, it threw the 'Coil low voltage' codes. This split second interruption of electric power caused the shutdown. Turning the switch off and then on, reset the system until it happened again. Tightened the connections and it hasn`t happened again. Have put about 4,000 miles on it since this incident with no problems.
Old Jul 1, 2009 | 07:01 PM
SixpackUSMC
Stage III
Thanks! I checked mine and it's tight. I did find some corrosion and water in that boot, though. Been a good bit of rain here lately and I seem to find myself out in it.
yankeeflyer72
Jan 6, 2023 05:51 AM
Emarz
May 20, 2014 03:16 PM
gtcole
Jun 21, 2010 08:49 PM
yankeeflyer72
Apr 22, 2009 10:47 AM
