Need Springer Help!!!!!
Old Sep 8, 2010 | 04:39 PM
scorchedearthpolicy's Avatar
scorchedearthpolicy
Originally Posted by SteveO-ll
any suspension outfit (i.e., energy suspension) has replacement bushings available, even in neoprene.
Good idea! I will check into that. Thanks.
Old Sep 8, 2010 | 09:10 PM
back again's Avatar
back again
Originally Posted by CroK
Cut a piece of fuel line of correct size and use that. It should last a while...
Or, possibly a piece of poly cut to fit...
I'll go back to what I said before.If that bushing is gone more than likely the shock is wore out. I did the rubber hose line and it still rode bad until I changed the shock.These shocks don't have a lot of damping even when new and even then it's on the rebound side.they are a maintenance item that move constantly and take a lot of the abuse the springer gets.Why take a chance half assing some thing that could kill you.Ever get a high end wobble or pogo,it's some thing you don't forget soon even if you don't go down.
xtremist
Mar 26, 2017 02:35 AM
DRTINC
Dec 3, 2012 11:35 PM
dynamike61
Feb 20, 2010 08:06 AM
scorchedearthpolicy
Dec 1, 2009 05:35 PM
StreetBobbin
Nov 21, 2007 03:47 PM
