total beginner question on shifting
Old Sep 17, 2010 | 06:52 PM
magforce's Avatar
magforce
my dyna likes 3500 to 4000 runs smooth as silk there.
Old Sep 17, 2010 | 07:04 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
30-45 mph is 3rd gear all the time. 45-60 is 4th 60-75 5th 75+ is 6th
Old Sep 17, 2010 | 07:12 PM
ev780's Avatar
ev780
Originally Posted by 08rock
I like to keep my engine at 2100 rpm that is where it feels right
+1
Use the tach not the speedometer!!
Old Sep 17, 2010 | 07:19 PM
BLKBAGGER's Avatar
BLKBAGGER
This sounds more like it. Rev that sucker out a little at least. Don't lug your motor!
Old Sep 17, 2010 | 07:25 PM
inaroush's Avatar
inaroush
I have a 2010 FB, cruising @ 35 mph I am usually in 3rd sometimes I may goto 4th if I know I will be at 35-40mph for a decent distance.
Keeps the engine revving low and just chillaxin on the move....
The biggest diff between yours and mine in I am EFI and you are Carb... Depending on how you have the carb set may change but I doubt it would have any major impact....
Old Sep 17, 2010 | 07:43 PM
FatJohn's Avatar
FatJohn
It's all about learning to "feel" when to shift. You need to practice to learn how to feel when the engine is reving too high or too low. If revs are too high, shift up. If they're too low, shift down. Too high and you'll hit the rev limiter / loose power / be really loud. Too low and you'll feel "bogged down" / like you're gonna stall / extra vibration. You learn to feel the "sweet spot" within the "power band" that you want to be in.
Then there's the "agressiveness" factor. If you're accelerating aggressively, you'll shift later (higher RPM, greater speed) than if you're accelerating leisurely.
Practice.
Old Sep 17, 2010 | 08:25 PM
Oldtigercub's Avatar
Oldtigercub
I agree with and will echo the suggestion that you shift when the bike tells you to. You should be focusing on the road and traffic, not constantly watching the tach and speedometer. You will get the feel of it. If the motor is racing, shift up. If it's bogging down at all, shift down. Be careful not to kick it down more than one gear at a time if you are moving very fast, though, you can lose traction at the rear wheel.
FroggyFatBoy's Avatar
FroggyFatBoy
Originally Posted by jimmers1817
Shift when the engine tells you to. If it's pulling good you're in the right gear. When the rpms get up and you're not getting any more speed out of the gear, shift up. If the acceleration feels flat or the engine is lugging, you need to downshift to the next gear.
e-yup
one other clue you waited to long to shift.. engine parts on the ground..
Old Sep 17, 2010 | 10:39 PM
2kids3pets's Avatar
2kids3pets
I run 2000 to 2500 in all gears...it just feels right
Old Sep 17, 2010 | 11:01 PM
editbrain's Avatar
editbrain
I have to go with the rev it up guys. You will find what your engine likes. Seriously the manual is a good guide, but you have to learn your bike. That is all there is to it. It took me a while to find where my bike likes to ride. I had to get use to the Big Twin. Now it is second nature. I like to keep the revs up because the bike is smoother, I have power when I need it, and I am not at risk of lugging the Big Twin.
Some times getting to cruise speed is dependent on traffic. Like rush hour. It sucks. Learn to leave for work earlier than usual. You will be much more relaxed, and your bike will be too.
