Amsoil superiority?
Old Oct 3, 2010 | 06:52 PM
  #41
BoomerBob's Avatar
BoomerBob
I think oil threads should be in the Political section since everyone seems to have passionate opinions about it. It must be the most debated topic on any forum for motorized vehicles.
Btw; Mobile 1 in the engine and primary and Redline Shockproof in the trans. Heheheheh ... just had to get my 2 cents in there too.
Old Oct 3, 2010 | 06:55 PM
  #42
WWECOUGAR's Avatar
WWECOUGAR
Originally Posted by boomerbob
i think oil threads should be in the political section since everyone seems to have passionate opinions about it. It must be the most debated topic on any forum for motorized vehicles.
:d
amen!!!!!
Old Oct 3, 2010 | 06:56 PM
  #43
Faast Ed's Avatar
Faast Ed
Motor oil in the primary?
Old Oct 3, 2010 | 07:02 PM
  #44
BoomerBob's Avatar
BoomerBob
Yep. On my "old" NT I tried everything in the primary and the Mobile 1 20-50 worked the best. Go figure, eh.
Old Oct 3, 2010 | 10:11 PM
  #45
Faast Ed's Avatar
Faast Ed
I haven't been able to beat Redline MTL in there.
Smooth shifts and great clutch bite.
Old Oct 3, 2010 | 11:37 PM
  #46
BoomerBob's Avatar
BoomerBob
Well that's one I haven't tried. Maybe I'll give it a try next oil change. Thanks!
Old Oct 4, 2010 | 06:22 AM
  #47
Faast Ed's Avatar
Faast Ed
Let me know how you like it. I'm guessing you will.
Old Oct 4, 2010 | 10:28 PM
  #48
oct1949's Avatar
oct1949
After trying syn3, formula+ and Belray,,,
I put in MOBIL Vtwin 20w-50 in the motor and Pri,,, and MOBIL 70-90 GL in the Tranny this summer,,,,
Ain't gonna be nothing but that MOBIL in her from now on...PERIOD.....
IMO it shifts smoother and runs cooler than any combo I've tried. and its easy to get.
Old Oct 4, 2010 | 10:54 PM
  #49
logdon17's Avatar
logdon17
Is it just me or is the entire oil debate overrated? I have been riding for many years and have seen many Harley engines with ten of thousands of miles. Not ONCE have I ever heard anyone tell me that they burned up their engine based only off of what type or brand of oil they used. The only time oil was mentioned as a problem is when an oil pump failed, or seals wore out and oil leaked. Keep it simple, change your oil regularly and it won't matter what you run.
Old Oct 4, 2010 | 10:55 PM
  #50
OldFenderGuy's Avatar
OldFenderGuy
Myself and most of the guys I ride with use regular ole' Rotella T 15W40 in the primaries of our bikes.
Never had a problem, and it costs all of about $2.50 a quart.
You don't really need to use expensive stuff in the primary, as the fluid isn't under any type of load or anything. It's main function is nothing more than to 'splash lubricate' the clutch pack and chain. Just make sure that whatever fluid you use doesn't contain a high PPM moly count which might cause problems down the road with the clutch pack.
For what it's worth, the email below verifies that regular Rotella T 15W40 has a JASO-MA rating, which means it contains very little (if any) moly so it is safe to use in wet clutch applications;
"We recently ran the JASO MA friction test on Rotella T with Triple Protection 15W-40, Rotella T Synthetic 5W-40 (CI-4) and our Rotella T Synthetic 5W-40 CJ-4.
All three oils passed the wet clutch friction test. Rotella T Synthetic 5W-40 (CI-4) has more than 1.2% ash (JASO MA spec limit) so it can not be classified as JASO MA. However, Rotella T with Triple Protection 15W-40 and our soon to be introduced Rotella T Synthetic 5W-40 CJ-4 do meet JASO MA."
If you have any additional questions please call us at 800-231-6950.
Thank you for your interest in Shell products.
Richard Moore
Staff Engineer
Shell Global Solutions (US) Inc.
Westhollow Technology Center
PO Box 4327
Houston, TX 77210
United States of America"
