View Poll Results: Have You Experienced a Compensator Failure?
YES
19
20.43%
NO
74
79.57%
Voters: 93. You may not vote on this poll
Compensator Failures? A Poll
Old Oct 5, 2010 | 09:10 PM
Steeltoe's Avatar
Steeltoe
I replaced mine with the SE comp at about 10,000 miles. It hadn't failed (yet) but it was banging pretty hard at startup and lurched a lot at low speeds in first gear (idling thru the parking lot). When I got the stock one out I could clearly see it was maxing out on the ramps. Local dealer said they couldn't do anything UNTIL it failed. I wasn't going to wait for that....
...and yes, there is a HUGE difference between the two.
Old Oct 5, 2010 | 09:52 PM
2kids3pets's Avatar
2kids3pets
Originally Posted by TheGeek
Well, I think my buddy has the issue on his 99 FLH. It sure was rattling the other night and he pulled it apart, and can't find anything. I am going over tonight to take a look. One question, how can you tell if it took a crap or not?
You should not be able to move the spring plates in the spring pack, if you can move them by hand its fokked
Old Oct 5, 2010 | 10:05 PM
joe.1955's Avatar
joe.1955
According to my dealer, all they do to test the compensator is remove it and shake it to hear if the springs are broken.
They said mine was ok (65K miles), but whenever I hit highway speeds I had to stay in 4th gear until 70 mph and couldn't use 6th at all due to the bike shuddering. It also banged pretty hard at startup, I think the spring pack was weak allowing the torque pulses to pass through to the frame.
I replaced it with the SE compensator, which is much heavier, stronger and better built all around - problem went away and I was able to ride 70 mph in 6th gear without seeing double.
Old Oct 5, 2010 | 10:19 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Nope...my chain is noisy but thats it.
Old Oct 5, 2010 | 10:40 PM
wideglidebob's Avatar
wideglidebob
whats a compensator
Old Oct 6, 2010 | 07:32 AM
skully_68's Avatar
skully_68
yep tried a solid sprocket for a wile didnt like the feel of that so i just replaced the spring pack been good ever since
Old Oct 6, 2010 | 10:54 AM
IronAss's Avatar
IronAss
Last time I had one go was in 1969 on my 64 Pan.
Old Oct 6, 2010 | 10:21 PM
oct1949's Avatar
oct1949
had dealer take out somr timing a zero RPM's on dyno tune when added cams and she hasn't clunked since then on start up...almost thirty K and she's fine on our 07.
Old Oct 7, 2010 | 03:59 AM
Thundermug's Avatar
Thundermug
Kinda like Harry helping Loyd....
http://www.youtube.com/watch?v=G4ev-BtPMM8
Old Oct 7, 2010 | 05:47 AM
Sefferdog's Avatar
Sefferdog
07 Ultra. Compensator replaced at 51,000. In the shop now for replacement again with SE comp, 86,000 on the odometer.
