Torque Wrench Recommendations
Old Dec 7, 2010 | 09:21 AM
PistonPuller's Avatar
PistonPuller
For what you are going to use it for and the amount of use, harbor freight is all you need. they are around $20 and just as good as craftsman only HF has a warranty.
Old Dec 7, 2010 | 09:29 AM
PirateRider's Avatar
PirateRider
Craftsman had their TWs on sale Thansgiving weekend for almost 50% off. I bought both a in/# and Ft/#. They were on sale for $50.00. These are the analog, not the digital. They are more than adequate for the weekend wrencher.
Old Dec 7, 2010 | 09:33 AM
petemac's Avatar
petemac
I've been using Craftsman for years and they work great. Get an inch pound and foot pound.
Old Dec 7, 2010 | 10:42 AM
osirisdean's Avatar
osirisdean
the three different harbor freight ones were $10, $20, and $30 when i got them. (figured for those prices, might as well get all 3 sizes.) never had a problem with any of them, they dont feel cheap, they came in hard plastic cases and seem to survive my abuse just fine. not sure why people are hating on the harbor freight torque wrenches, theyve served me very well for over a year now.
Old Dec 7, 2010 | 01:08 PM
rafael53's Avatar
rafael53
funny...just sitting next to our lead mechanic asking the same thing.
For my needs and cost, just to work on my bike around the house and not for a job, harbor freight is what he recommended....are both sufficient and reliable.
Old Dec 8, 2010 | 09:20 PM
Elgin47's Avatar
Elgin47
I've had both Craftsman and Harbor Freight, 3/8" and 1/2" drives, for my needs they worked just fine.
Then my son got me a 3/8" Snap-On electronic for Father's Day last year, never would have popped for it myself but it's nice - real nice.
Old Dec 8, 2010 | 09:23 PM
xxxflhrci's Avatar
xxxflhrci
Another HF user here.
Old Dec 8, 2010 | 09:25 PM
dedjr67's Avatar
dedjr67
For work I use a Snap-on Digital model but that is how I make my living. I used a Craftsmen half inch torque wrench for years ( I still have it at the house for use on the bike) If you buy one from Craigslist you have no way of knowing if it was cared for properly.
Old Dec 8, 2010 | 10:36 PM
Bluehighways's Avatar
Bluehighways
Originally Posted by tx-skydiver
I have a Harbor Freight model that is much cheaper and all metal (unlike Craftsman that has a plastic handle). It works as well as my Craftsman did (before the handle became brittle and broke.
Oh yeah...Craftsman does NOT give a warranty on those.
I used make my living with my tools and had a Snap-On Torque wrench then. Actually I still have it, but the ratchet drive broke and Snap-On calls it an antique and doesn't make replacement parts for it. very sad indeed! Ignoring for the moment that this may represent a back door way of discriminating against a Senior Wrench for working around my toys, I bought a Craftsman. Danged if the plastic didn't split just like you are describing . . . so I took it back to Sears . . . no luck without the original receipt and less than a year old. Sure isn't the Craftsman Tool Warranty old. I'm going to call AARP on both these companies! So I went to Harbor Frieght and got a complete set or torque wrenches: 1/4" Drive - Inch Pound - click type, 1/4" Drive - Inch Pound - torsion bar type (for measuring bearing preload turning torque), 3/8" Drive - Ft./Lb - click type and 1/2" Drive - Ft./Lb - click type . . . all total was less than one replacement Craftsman, and a fraction of a new Snap-On of course. . .
Old Dec 8, 2010 | 11:10 PM
Tech23's Avatar
Tech23
Originally Posted by carlgrover
I'll vote for Craftsman as well. However; you really should buy two torque wrenches. One in ft/lbs and one in in/lbs. Some of the torques are really light and that is getting on the bottom of the scale with the ft/lb wrench. If it were me and I was on a budget, I would go for the ft/lb wrench now and think about getting an in/lb wrench in the future. "Most" but not all critical torques have a relatively high value. I've had a ft/lb torque wrench for years and put an in/lb wrench on my Christmas list this year.
Carl
That's correct, you will not find a single torque wrench to do it all on your bike or you car either. If you want to be able to do it all (with accuracy) you will likely need three torque wrenches A 1/4 or 3/8 inch pound torque wrench with a range of 40 to 200 in/lbs, a 3/8 drive torque wrench with a range of 5 to 75 ft/lbs and a 1/2 in drive from about 40ft/lbs to 250ft/lbs or as high as you can find. A good start would be a 3/8 drive with a 5 to 75 or 80 ft/lb range or higher if you can find it A flex head would add versatility. For high torque specs I like the Snap-On torsion bar style torque wrenches. The handle does not get shorter as you dial in higher torque settings like the micrometer style torque wrenches do. This would be the 1/2 drive torque wrench...the biggest wrench you will likely need.
Tech23
