Almost laid it down
Old Mar 2, 2011 | 08:10 PM
TurkeyRun's Avatar
TurkeyRun
with the engine guards mine wasn't went over, it stops about 45*, easy to roll back upright..
Yup - like this
{gal on left} - wow, he dropped his bike
{me in middle} - wow, I dropped my bike
{RLAP Instructor on left} - dude, you slowed down!
Old Mar 2, 2011 | 08:14 PM
jlasoftail's Avatar
jlasoftail
A local guy broke his leg trying to save his bike from going over at about 3mph. Best advice: don't let it get to that point. Lots of great videos on youtube, and some other great sites so take your time and learn, and if you need it, hit the parking lots on sunday to practice.
Old Mar 2, 2011 | 08:35 PM
barjbar's Avatar
barjbar
With experience you will learn to park where you can pull straight out or if you have to back out of a spot, make sure it's at least level so you can push he bike out. Another tip is when you put your feet down, have your toes pointing about 10 and 2 - not straight forward in the same direction as the bike. Your entire leg takes the weight, not just your ankles and you will see it's much easier to keep the bike upright. Try leaning the bike with your feet in both positions and you'll see not only can you lean the bike much farther without any difficulty but with your toes in the 10 and 2 position on the ground the seat will hit your thigh and your straight leg keeps the bike up.
Old Mar 2, 2011 | 09:49 PM
oct1949's Avatar
oct1949
leaned a long time ago, when U need to back up,, bounce Ur front forks down with the front brake on, and then push backward on the bike on the upstroke of the shocks,, try it,,, it works really good.
Old Mar 2, 2011 | 11:20 PM
arcticharleyman's Avatar
arcticharleyman
I've used that little trick when my front or rear wheel decides to try & f' me up by resting in a hole and I have to back up, or when I have to get my front wheel out of a gutter. I've also used it to back my bike into the toyhauler or my garage (I have to run up a bit of a ramp since I relocated my garage and poured a new pad that is 6" higher directly behind the old one) when no one else is around to help me.
Old Mar 3, 2011 | 08:06 AM
BassCatcher's Avatar
BassCatcher
When I had my sportster I just never felt that this was much of a problem. With the Heritage, it's a whole 'nother ball game. You will learn with practice. Always look down to make sure you are not backing up your bike with gravel on the pavement. Gravel or sand is your worse enemy. Even with decent lugs on my boots I will still slip a foot if not careful.
Get some engine guards...they are cheap nowadays.
Old Mar 3, 2011 | 08:12 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
New rider? I have two tips:
1. If you don't have an engine guard...go get one installed today.
2. Get a "ride like a pro" DVD and watch it several times and practice.
http://www.ridelikeapro.com/
Old Mar 3, 2011 | 09:23 AM
Spindrifter's Avatar
Spindrifter
Old Mar 3, 2011 | 09:31 AM
taximan62's Avatar
taximan62
One big question. Did you use your front brake when you were pulling in. A common mistake of new riders is not knowing that when doing slow speed manouvers that you only use the rear brake. Using the front while turning going slow in a parking lot will make the front end dive and you will lose control of the bike.
The first thing you must master is head and eyes. What this means exactly, is that wherever you look, that's where the bike will go. The reason the phrase head and eyes is used is that if you turn your head to the right, but your eyes look straight ahead, the technique WILL NOT work. Both your head and eyes must turn in the direction you want the bike to go. Never look down unless you want to go down. Head and eyes does take practice to become second nature. The good news is that you can practice this technique every time you are on your motorcycle. Simply pulling out of your driveway, for instance, if you are turning to the right, turn your head and eyes to the right, look down the road where you want the motorcycle to go and you'll immediately notice you will be making a much tighter turn than normal. When you stop at a stop sign and are about to make a left hand turn, turn your head and eyes to the left, avoid looking at the curb or the center line of the road and focus on where you want the bike to end up and you will find you will never drift towards the curb or the center line of the road. You can even practice this technique on a bicycle by making U-turns on the street in front of your own home.
The second technique you must learn is how to use the friction zone. The friction zone is the area on the clutch between fully open and fully closed. In other words, as you let the clutch out and the bike starts to move, you're entering the friction zone. An easy way to become accustomed to riding the bike in the friction zone is to practice the slow race. That is simply going as slow as you possibly can without releasing the clutch completely.
The third technique is the proper use of the rear or controlling brake. With the motorcycle in the friction zone, keep your foot on the rear brake and feather it as the bike starts to move. By doing this you are making the motorcycle think it's going faster than it is. When you apply power and keep your foot on the rear brake, it keeps the motorcycle from falling over at low speeds which is where most people have a problem. I've never heard of anyone having problems balancing their motorcycle at 50 or 60mph. If you don't use these techniques at 5 or 10mph the motorcycle feels clumsy and wants to fall over on it's side. AVOID using the front brake at all costs when riding at parking lot speeds, as applying the front brake at 5 or 10mph with the handle bars turned even slightly, will pull you to the ground like a magnet. Of course, once above parking lot speeds, you must use the front brake as well as the rear brake, as 70% of your braking power comes from the front brake.
Avoid dragging your feet along the ground as this tends to upset the balance of the motorcycle, and of course, if your feet are dragging on the ground you cannot have your foot on the brake. As soon as you start to move your bike from a complete stop, both feet should automatically come up to the floor boards or pegs and your right foot should be feathering the rear brake. Once you master these three simple techniques, you will be amazed at the tight maneuvers your bike can perform. You'll know you've gotten it right when you can make full lock turns in both directions at 5mph with the pegs or boards scraping a perfect circle in the pavement.
Old Mar 3, 2011 | 09:43 AM
Throwback's Avatar
Throwback
Hard to save it once it get past a certain point. There are those who have dropped it and those who will.
