Rusty threads
Old Mar 10, 2011 | 06:41 AM
vtwinhd59's Avatar
vtwinhd59
Default Rusty threads
I've got a 2010 Streetglide. Ive recently noticed some rust already starting inside the screw holes where the passenger peg mount attaches to the bike. Any ideas for a plug or something to pop in there to keep water out. Any idea what size hole that is too.
Old Mar 10, 2011 | 06:52 AM
Mike T's Avatar
Mike T
They make chrome plugs to go in those holes. You'll just have to figure out the correct size.
Old Mar 10, 2011 | 06:59 AM
1flhtk4me's Avatar
1flhtk4me
Besides plugs you could probly put in some bolts,button head screws,etc-
Old Mar 10, 2011 | 07:03 AM
handyhoward's Avatar
handyhoward
If I have said it once I've said it 100 times... the best way to prevent rust is to spray your bike down completely at least once a year with a can of WD40 or Jigaloo. It works itself into all the hidden crevices and the sort where rust starts... just wipe off the parts you touch until your first wash job. And wait a week or two before that first wash to let the water displacer do its job.
Old Mar 10, 2011 | 07:06 AM
Notgrownup's Avatar
Notgrownup
Lubricate it..If you cover it with caps or chrome make sure you lube it because the rust will eat it up if you don't....
Old Mar 10, 2011 | 07:07 AM
dog155's Avatar
dog155
Better than WD-40 would be a chain lube or white lithium.The threads are 7/16" and HD does have caps for the holes.Welcome to the Harley family!
Old Mar 10, 2011 | 07:20 AM
1flhtk4me's Avatar
1flhtk4me
You should also try to remove the rust first.Gun barrel brushes work good.
Old Mar 10, 2011 | 07:38 AM
vtwinhd59's Avatar
vtwinhd59
Thanks for all the replies. Glab to be here. I do the wd40 thing it just seems to attract a ton a dirt and dust. I guess it's better that rust
Old Mar 10, 2011 | 08:03 AM
handyhoward
The problem with chain lube or white lithium is that their use is restricted to just one or two applications... you can spray the whole bike down with WD40 and not worry. Also, I have found that WD40 penetrates any existing rust and stops it dead... no need to scrape and risk chipping off the paint as well.
Old Mar 10, 2011 | 08:07 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I use G-96 gun treatment under the frame once a year and after the bike has been washed and is completely dry. I don't know what is in it but it keeps blued firearms rust free. Works great. Sprayt it on, wipe with a rag ....done.
http://www.g96.com/miva/merchant.mv?...=Gun+Treatment
