Sporster question (backfire)
Old Apr 5, 2011 | 09:32 AM
HarleyNation's Avatar
HarleyNation
Default Sporster question (backfire)
Usually I would pull out the choke and let it run for about 10 minutes. As I take off rolling on the throttle the bike backfires and attempts to stall. I roll off slowly then roll on the throttle again and it runs fine..Is this normal? Or what could be the problem?
Old Apr 5, 2011 | 09:59 AM
RutRoo's Avatar
RutRoo
It's the nature of the beast. Just not warmed to where it wants to be. My sportster does the same.
Old Apr 5, 2011 | 10:00 AM
HarleyNation
Ok, thanks I was worried..If I was doing something wrong or somthing..new rider here
the blob's Avatar
the blob
is it carb farting or backfiring out the pipes? using the choke for 10min is way too long! you could be fouling the plugs!! use the choke as little as possible. i use mine to start up then as soon as the motor gets going,no more than 30sec.s to 1 minute i push the choke in and use the throttle lock to keep it from stalling till it warms up and can idle on its own.
Old Apr 5, 2011 | 10:02 AM
HarleyNation
Throttle lock, no one has told me about that..ill do some research and learn how to do that...also RutRoo..where are you in East TN?
Old Apr 5, 2011 | 10:44 AM
vet767's Avatar
vet767
Plastic star screw/nut under the throttle grip. It is a friction lock, on bikes w/o cruise control you can tighten it to hold the throttle in place while on a trip where your speed is realatively constant. Less stress on the hand. I prefer to pull the enrichener out fully to start the bike (both the sporty and the fx). Once it starts push it in until the idle slows a bit, like about half way. Put on my gloves, zip my jacket, put my glasses on and roll out the driveway. Once I am rolling push the thing in all the way. If you come to a stop it will let you know if you need a little throttle to warm it up some more.
Old Apr 5, 2011 | 10:51 AM
HarleyNation
Thanks alot everyone
Old Apr 5, 2011 | 11:20 AM
Robotech's Avatar
Robotech
This is my routine too. Works like a charm and never had any backfire/carb fart issues.
Old Apr 6, 2011 | 08:01 AM
WVHogRider's Avatar
WVHogRider
Or you could adjust the tensioner on the choke/enrichner so that it will slide back in on it's own as the bike warms up. But I agree with the others if yours tensioner isn't adjusted. Choke all the way out, one or two twists of the thottle, & hit the start button.....Then push the choke back in about half way to slightly slow the idle while finishing throwing on the glasses/gloves/helmet/etc.
Old Apr 9, 2011 | 11:57 AM
TateEvan's Avatar
TateEvan
I love my mikuni, just reach down and turn up the idle...
