help w kuryakyn hypercharger
Old Apr 6, 2011 | 06:12 AM
magna's Avatar
magna
Ive got one, as has been said not to bad to take apart, had no problems with mine, got to admit though it would'nt have been my first choice but when i bought my 06 bike there wasnt a lot to choose from for an efi type engine.
Old Apr 6, 2011 | 08:58 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
I don't think theres anything wrong with the cleaner, like the look, takes in plenty of air, kurakyn stands behind all they make, will serve you well, are there more efficient filters? probally, but if your mortor is stock or slightly heated up, that filter is just fine, worse part is its a little bit of work to clean the element, but I lir the look on the right bike. don't let other's opinions sway you on this, you aren't doing anything bad for the bike by running this filter. if you don't like it, then change it but it is a good filter.
Old Apr 6, 2011 | 08:59 AM
harleycharlie1992
watch out for your "morter" getting heated!! was supposed to be "motor"
Old Apr 6, 2011 | 11:48 AM
xwhyz1959's Avatar
xwhyz1959
Does yours not have the "trap door" on the side to access the air filter? Mine does, 4 screws and it's accessable.
Old Apr 6, 2011 | 04:29 PM
QehQeh's Avatar
QehQeh
Originally Posted by dickey
Take off that hypercharger & throw it over the fence. They're junk. Go with the Screamin' Eagle assembly, then junk their element in favor of a K&N. (looks similar,but K&N is the best & the HP difference IS noticeable). You can't go wrong with SE stuff...
+1
Of course I can only speak from my own experience but around this neck of the woods, the only thing the HYPErcharger is good for is getting a good chuckle out of your fellow bikers.
Old Apr 13, 2011 | 08:36 PM
chrishicks3603's Avatar
chrishicks3603
thanks for all of the advice. Got out there and took it apart w no problem at all. I figured what the hell if I screw it up I will go to a big sucker or screamin eagle. Got it all cleaned and put back together......And for the 250 bucks that it would cost me to switch it over to something different...Well I figure this is money well spent on gas for riding!
Old Apr 13, 2011 | 09:52 PM
Rebel Ryder's Avatar
Rebel Ryder
bought mine w/it attached to a mikuni 42, and kept it. as another said I actually like the flapping butterflies. however, I did go the K&N route and she breathes just fine!
hullhorr
Touring Parts
Oct 24, 2015 07:13 PM
2011FXDC
Dyna Parts
Feb 21, 2013 03:10 PM
shakak
Sep 23, 2012 05:40 PM
k-hook
Jun 12, 2011 09:13 PM
buckshot
Exhaust System Topics
Feb 4, 2008 08:10 AM
