Need help adjusting my PC-V
Subscribe
Apr 9, 2011 | 09:23 PM
I got a PC-V retrofit unit from Fuelmoto, put it on, got a little decel popping so I talked to Keith yesterday about how to adjust it. Since I don't have a laptop I have to take the unit off the bike and plug it into my home computer. No biggie. Well I did that and the computer recognizes the device and retrieved the map, but I can't do anything to it. All it says is Custom Map by Fuelmoto, but I cant open any tables or anything to make adjustments. Help me please. I thought this was supposed to be simple.
Apr 9, 2011 | 09:28 PM
call Keith
Apr 9, 2011 | 09:33 PM
I would call Keith if it wasnt 10:30 on a Saturday night. Anybody that can steer me in the right direction with this thing now?
Apr 9, 2011 | 09:43 PM
Expand the map, click on the cylinder & then the table you need to adjust, change the values that Keith told you to (probable column 0, from 0 to 15), save the map (give it another name so you keep the old map) and then send it to to the PCV.
BTW, you may have to edit the original map stored in your computer or in the backup file if you you can't adjust the one in the PCV or save the PCV map to your computer & then edit, save & send.
Apr 9, 2011 | 09:47 PM
How do I expand the map?
Apr 9, 2011 | 09:51 PM
Quote: How do I expand the map?
Click on the + or right click with your mouse & select expand
Apr 9, 2011 | 09:52 PM
I wish someone could see what I'm looking at. It is just a big empty white box, and a bunch of green zeroes off to the right. I have clicked everything thereis to click, nothing gives me access to anything that I can do anything with
Apr 9, 2011 | 09:54 PM
As far as it will expand is to primary module, and thats as far as it goes. Nothing else opens
Explore
Apr 9, 2011 | 09:58 PM
Quote: As far as it will expand is to primary module, and thats as far as it goes. Nothing else opens
Do you have any - or + symbols? Try opening another map too.
Apr 9, 2011 | 10:01 PM
I have - symbols in the upper left hand corner next to Device Network and Map Position 1. I can collapse it down or expand it, bu tit only goes to primary module and thats it. I only have the one map, as it is a brand new unit
