2011 Model technical information
Believe it or not, I was working on the CAN product in 1998 on transit busses. You know, those big mobile people movers in the city. It's a simple input/output signal or I/O technology.
You press a button for a function to happen; say the horn. The BCM receives the signal from the button, understands what the signal means, and sends a voltage signal to the horn....which will blow but no car will hear.
putting a CAN system on a bike is rediculous.. i don't need a computer to ground a horn relay when the horn button already does that direct to the relay.
i had a car come out of the body shop that wouldn't start, the immobilizer system light was flashing and no odometer display.. well after about 3 days or tracing wires, checking voltages, some reading in millivolts.. it came down to a cascading failure.. when the harness was damaged in the accident, it took out the PCM, the harness and Cluster.. what a cluster F... it cost well over 3G buy the time it was all done..
ken b
Aug 22, 2011 03:06 PM
LngRidr
Aug 5, 2010 06:59 AM
2011, bcm, change, date, dealers, flstc, harley, hd, httpwwwboxnetsharedtn3p9rogs6, info, location, meeting, model, presentation, yearuseful
